Geofencing. not working
I would expect this from other companies but from netgear???? Think it's time to get my money back!!!
OK so we finally get Arlo which we were excited about. We have 3 people in our house and well this system should be able to be armed and disarmed when anyone of us comes and goes.......or so you'd think.
NoHelp, SayWhat?
Set up IFTTT:
IF first family member arrives HOME then disarm arlo (Using life360 and arlo)
IF last family member leaves HOME then arm arlo (using life 360 and arlo)
3 IPhones set up with life 360 which have been working for the last 2 years
Member #1 comes home alone - Arlo disarms
Member # 3 comes home alone - Arlo disarms
Member #2 come home alone (the member that set everything up) and we have motion alerts going off left and right.
Yes, I set up everything the way it should have been set.
Search for Support number.... can't be found but find "Live Chat"
First support person is of no help and disconnected
Second support person gives me phone number and advises me to set up Geofencing and walks me through steps. Tells me THIS WILL WORK!
Call Support (Speak to someone in the Philippines ....... WHAT?? No USA Support????) And after being on hold get disconnected
Member #1 comes home alone - Member #3 gets 14 motion alerts even though the app says that member #1 is "IN THE ZONE" which means the system should have disarmed. Nope, Not my Arlo!
Look online for the Support chat and it's nowhere to be found but today, the phone number is there (crazy)
Call Support again.... yes, another person in the Philippines (nothing against Philippines but why no USA support???) This person knows nothing about how to fix this and suggests that I (member #3) remove myself from the system all together (Take my name, number, everything off the website, take the app off my phone) and this should help...... Ummm..... WHAT????
So I have to completely remove myself from everything just so I won’t get any alerts on my phone? Instead of someone coming up with a way to arm and disarm this system when different members of the family come and go??? Nope, not working for me!!!!! Support person asks me if I mind being put on a 5-7 minute hold? Um.... again... WHAT???? No. Im not going to wait 5-7 minutes.
Yes, Support person puts me on hold anyway and there I sit for about 15-20 minutes listening to some horrible music when CLICK....... Disconnected!
Can you even imagine how happy I was at that moment???? Yea, not very happy.
So here I sit, with all three members in the house and my phone flashing on and off.![]()
GEOFENCING AT HOME IS NOW HOME MODE
GEOFENCING AT HOMOE IS NOW AWAY MODE
MOTION DETECTED ON PORCH
MOTION DETECTED IN LIVING ROOM
MOTION DETECTED IN BASEMENT
YEP exact same issue after iOS update of the app to version 2.4.7. No longer recognising when we are away or back home. If device is showing out of zone then it will stay out of zone even if we arrived back home and vice versa.
The app does not seems to be running in the background. If I open the app, minimise it, wait few mins and open it again, it went back to beginning where it will try to log me in from start.
Netgear are you listening, fix your freaking app. and Yes I have done all the "disable/enable" devices steps and have even gone as far as reset to factory default and resync all my cameras and resetup GeoFencing.
After 48 mins and 16 seconds of waiting, I finally got to speak to a ‘technical’ person who was very helpful but unable to fix the geofencing problem (which wasn”t a problem until a week ago).
I made it clear that he needs to send this problem up the line and fix this issue or I will be returning my 3 month old Arlo system as it no longer meets the manufacturers claims.
Here is the email follow up recommendations from my technical call, which I have followed with no success:
Here are the workaround that you may try to fix the issue on your geofencing.
1. Phone name should not contain any special characters under Geofencing's enabled devices.
iPhone=( Phone settings > General > about )
Android = Phone settings > About Device
2. After changing the phone name under the phone's settings, make sure that you powercycle the phone so that the change name will be applied.
3. Make sure that location services is enabled for the phone, and is always available for the Arlo App
iPhone= ( Settings > Privacy > Arlo )
Android= ( Settings> Location Services)
4. Now, devices should now show up under the Enabled devices page under Geofencing, but these devices may show "Unavailable".
5. To fix this, uncheck all devices > Done > Save.
6. No device should be enabled for geofencing now.
7. Check all devices again > Done > Save.
8. Devices should show the correct status and Geofencing should be working.
We appreciate the time assisting you. Thank you for choosing NETGEAR.
Regards,
XXxx
Expert ID: xxxxx
NETGEAR Support Expert
Yes, same issue with IOS also. run the app and few mins later try to open the app, it goes back to login screen and ask for login again.
GeoFencing needs the app to be running in background to be able to works which is not the case after the latest update.
FIX IT!!!!!
I´ve got exactly the same problem since last update:( Worked just fine before.. please fix this!
I've also had the same problem the last few weeks.
Thanks for the good discussion on this issue. Especially for the effort vk2gho made contacting technical support. I have also tried all those fixes and nothing helped. Looking at information in the app it is apparent to me that the app knows if the phone is "in zone" or "out of zone" but for what ever reason it is not automatically switching modes. That being said as I mentioned it did work for me yesterday. I can also force the switch by going into the app and selecting a different mode then switching back to Geofencing mode. Once you do that the app will select the proper mode. It is clear something is either wrong with the app or a change Apple made to iOS.
For me this started getting intermittent several months ago. I noticed it might take an hour or more before the app realized I was out of zone. Within the last few weeks it stopped work completely except for yesterday.
Hopefully Arlo will respond.
Mine also does not kick in until the app is opened.
I have noticed this for a few months now.
A response from Netgear would be nice.
For example: We are working on it.
Everyones phone is not compatiable with our product...
I could go on for days.
I don't use GF but that implies that the app is sleeping. I hope you've tried the battery optimization changes but, unfortunately, if that doesn't help, I suppose that's not the real answer.
Same problem. App says you have left or entered home area, but does not actuall arm or disarm the camera . worked once. never again.
Netgear fix this issue, Supoport is the group who told me about geofencing but it does not work.
The app found my phone name even with an apostrophe. i removed it and will test to see if it works. i will focre quit thecapp and restart it
For the second day in a row the geofencing is working. I don't know why but I am hoping Arlo made some changes to fix the problem. My phone is a iPhone 7 Plus so I do not believe it has the battery optimization features. And I do not believe the app is sleeping. I know the phone is not.
Engineering is currently aware of and investigating an issue with Geofencing that is affecting some users. I will provide an update as soon as I have more information.
Hi JamesC,
Your statement about GeoFencing affecting some users is an understatement! It is affecting both iPhone users and Andriod (Samsung) users. Bear in mind that iPhone used to work flawlessly but someone broke it recently!
Can you be more specific of what users/devices/etc?
Hi edif30,
If you are from the Arlo App development team, have you tested the app and are you saying that you are not able to simulate the problem in your environment? This happens to not just one user but multiple users and it is not specific to one platform. I have a iphone 8 with the latest IOS code which was working until recently. My wife has a samsung S8+ and both of them are not working (for the geofencing). The status doesn't update the status regardless of the mobile leaves the security perimeter or enters the security zone that is defined in the geofencing setting. I am away/out from my house and it is showing that I am in zone while my wife is at home but arlo geofencing app is saying that she is out of zone. This is getting ridiculous!
