Usu, when Live video doesn't work, It's a FLASH issue.
Have you upgrade anything lately ? ( many new prgms toggle off flash as default )
Same issue on MAC using Safari, and Chrome, as well as my iPhone and my wifes iPhone.
I can watch previously recorded video.
Same issue on this thread
@Support anyone reading these similiar issues? Sounds like firmware issue bug.
Having exact same issue...did everything you did to no avail..need answers
It appears there was an update yesterday to firmware update 1.12.2.0_2790, since then none of my cameras are working. Any suggestions?
Already tried rebooting internet, basestations, and re-syncing the cameras and nothing is working.
What are the base LEDs showing? Have you tried rebooting the router and base, in that order? Have you tried a browser?
What are the base LEDs showing? Should be 3 green ones.
It may be fastest to reset the system and start fresh. Remove all devices from Settings, My Devices. Hold the reset button until the LEDs flash amber. Use the Add Device selection on the Devices tab to claim the base. Sync the cameras. Update firmware as you go if propted.
My Arlo hub occasionally goes offline. When I am home, I reset it by unplugging it and plugging it back in. However, when I am away, I can’t do that. Are there any solutions for getting the hub back online remotely? Alternatively, does anyone know of a reasonable priced outlet that can be turned on and off remotely via the internet? Thanks
Consider a UPS for your modem, router and base. In addition, you can use any WiFi switch such as WeMo (there are many others).
Seems like arlo and netgear are having issues
My base station is down at the moment and I cant seem to get it going.
Things I've tried
Updated firmwire which literally takes forever and a day and doesn't notify you when it's been done
Then my base station shows as offline
I've tried restarting rebooting and reloading cams on to a new base station but because of this firmwire crap it wont detect anything
If there is anyone that can help me because arlo seem like there on a long holiday and are not replying to anything
I have tried everything!! Most frustrated with Netgear ARLO. I still cannot connect to my cameras via the mobile app nor online.
We are having some of the same issues, except video is extremely blurry and choppy. Recordings are also only about 10 to 12 seconds long. Arlo seems to like to mess a good thing up with these updates they do.
I just spoke with "tech" support. They know abou the issue and are working to resolve it. Sad that our cameras rely on an external connection to work!!
I just spoke with "tech" support. They know about the issue and are working to resolve it. Sad that our cameras rely on an external connection to work!!
unplugged my hub (vmb3500) twice brfore media server issue went away
Same here..went thru all the recommendations reset, cleared ,added devices, etc. and still same issue. Base has all three solid green lights, camera's connected (synced) to base, full battery-but get same error with no video...
Same issue.
And I've tried reaching out to Arlo via chat and email and both do not work! Just left hanging here for a supposed security system. There status page says everything is up and running.... but appears to not be when I browse all the comments on here.
Anyone have an email address for Arlo support?
