Hi Guys,
I just got my system updated with these firmware versions
Base = 1.4.2627
Camera = 1.2.2545
and it's really buggy.. I hope they'll release a new one soon and take care of it..
Problems:
1. Recording is randomly glitchy. It sometimes would not record even though it shows in my iphone's
Notification there's motion detected.. Library shows nothing.. Also checked on my email and there's none..
This is not good.. It beats the purpose of what this system does.. I can live with other glitch with this system
but not this one.. Earlier Firmware Version of base & camera were working fine..
2. iOs App 1.8.1 recently would crash on me randomly when accessing.. Especially when doing
scheduling or streaming from library.. Earlier Firmware Version was working fine..
3. When streaming live on my cameras, I sometimes have to press play several times coz it would not work the
the first time when pressed.. This is happening thru my iphone using the latest App 1.8.1.. Again, Earlier
Firmware versions of base & camera were working fine..
I wish I could go back to the earlier Firmware version..
Regards,
Jon
JPC wrote:Here's a list of Firmwares that I wish Netgear would allow us to install..
There might be good reason why you don't want to use these. 😄
It might be nice to have the ability to change firmware, especially to backdate when problems occur with new firmware. However, it might also lead to increased support issues when folks blindly change firmware "just because". Ever notice that the temp gauge on your cars never change unless towing huge loads up mountains or racing? They're highly damped/dumbed down to reduce service calls. My 1970 Fiat 850 Spider has a true mechanical gauge that wanders according to driving load. I prefer it to the damped one but 95% of the population would probably have service done becuase "the car's running hot"...
JPC wrote:How can I become a beta tester here? Is there an application or something? Do I need to get lotsa' KUDOs? LOL
beta testing is done, it was back in oct to dec+ release
Now and then netgear will ask for betas from the main menu... and have apps to apply.
<<So Tom, with the newer version you are currently running, can you say if the delay that a lot of users are experiencing, got any better or worse?>>
My responce time has always been pretty good from the last to current versions... no major change that people would prob notice. I notice a VERY slight improvement in sensitivity time ( we're talking like a fraction of a second ). I can say that I've always had pretty good responce time tho... be it the experience running 5 vuezone cameras for 2 years and having Arlo for the beta testing OR having a good thruput internet connection OR both.
That a lot of people seem to be having delay problems can be a varied reason/problem...location/settings/internet connection/interference/etc... the learning curve is there in the end use too
jguerdat wrote:There might be good reason why you don't want to use these. 😄
Am sure one of those firmwares is good to use with less bug than the recent one, for my system at least.. Although, it took care most the major issues I had but glitches sure shows a bit more compared to the last firmware..
Percentage wise, I think it would not increase too much the support issues..I think it would help ease up the support issues because we know which firmware is working for us.. It can also help the support team to resolve the problem in no time coz' of us giving them feedback..
Thanks Tom!
I turned my auto updates off because the last updates not been working well. How do i get it to update to the newest firmware on the base? I turned auto updates back on. I'm at 1.4.2627. i also restarted the base thinking that would force it to update, but it has not.
@Jody..
to my knowledge version 1.4.2627 is the latest full released version.
There may be one or two out there that have a newer version for testing purposes only, but not fully release to the masses.
I just started having the issue in the last few days...is this still an issue for others? Has there been a fix? Thank you.
cjpofd wrote:I just started having the issue in the last few days...is this still an issue for others? Has there been a fix? Thank you.
In my case, I'm experiencing a bit more glitches with this new firmware than the previous one.. I hope Netgear will release an update soon with a much more stable one.. But if you're having some issues recently, it might be related to this here:
https://community.netgear.com/t5/Troubleshooting/No-live-stream-or-video-for-today/m-p/8285#M2003
