Distorted video
Hi I keep getting completely distorted videos being captured - sometimes it works fine then I’ll get 3 or 4 in a row that are either blank grey or covered in lines (see image) - any ideas?
6 REPLIES 6
Hi @Mikeday1uk
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Hi - I’ve changed the batteries and rebooted both the hub and my router. Beyond that I’m out of ideas.
If it was happening all the time I’d think it was a weak Wi-Fi signal but it is only happening sporadically
Have you tried to remove the cameras from Settings > My Devices > Re-add them?
Just tried that now will see if it improves thanks!
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
