New VMB4000 base station. When I try to add it in the app or using the web, nothing shows up after the search. The lights on the base station are as follows:
Power - solid green
Internet - solid green
Camera(s) - solid amber
I think it may be bad. The camera light shouldn't be solid amber with no cameras added, should it? Any ideas?
Lou
Best answers
The issues you're experiencing could be due to a hardware issue. We ask that you reach out to support for more information. You can get to support by going within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing. If by chance you do not have a subscription and are unable to reach out to support please send me a dm and I will create a ticket for you. You send a dm by clicking on the envelope icon on the top right of the forum page.
Are you using the primary account? Or are you perhaps using a "friend" account?
Same here. I’m primary and it goes from online to offline multiple times. Internet working without drops. My wife, friend account, is always offline. But cameras work and notification works also but geofencing doesn’t. Quite frustrating
Thanks,
Maybe ARLO can find a solution!
Primary
Hi, here's my scenario:
my VMB4000 hub was working, but I wanted to remove and re-install,
after deleting cameras (4 pro 2's) I installed the hub
first 2 leds are green, 3rd is amber
hub shows up on my phone in wifi settings as ARLO_VMB_(THEN 10 DIGITS) locked
I use the app and I've tried with laptop via logging on to arlo account etc
everytime it says No Arlo devices found
can anybody tell me what I am doing wrong?
TIA, Brad
In addition to the article Edinburgh_lad1 provides, other users have reported similar issues to importing their arlo base station again.
From your description of the base led display it confirms that the base has been successfully factory reset given the camera led is now showing constant amber illumination so it is ready to be claimed by a arlo account.
it is important to note that the arlo app device needs to be connected to the local network that the base is connected to for the app to find the base. I.e. mobile using the local wifi or the pc web browser using an Ethernet connection.
the recent reporting of the problems points to a bug in the arlo app that is preventing some older base devices being imported.
Make sure you have removed all arlo devices from the account before trying to import them again.
to date arlo has not provided any update to when or if it will be resolved.
It appears that your hardware may be defective. We ask that you reach out to support for more information. You can get to support by going within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing. If by chance you do not have a subscription and are unable to reach out to support please send me a dm and I will create a ticket for you. You send a dm by clicking on the envelope icon on the top right of the forum page.
Hi, thanks for your reply. Yes, it’s on the same network. (Ethernet) and 2 green lights one amber (no cameras attached)
I’ll send Arlo a query
cheers
This is exactly what I'm facing. Base loads to devices on PC portal no problem. Cameras and base both blink slow then fast, but don't show up in devices. Problem started after removing cameras from devices. Everything was working properly.
Problem solved, spoke with Arlo support and would not work after resets etc, then used another device (my wife’s phone) and the base station showed up and connected! Weird as our phone are exact same (iPhone 15 pro max) thanks for Arlo support
Base Station VMB4000 is not being detected.
Only the far left LED is Amber the other two do not light up.
I reset it to factory settings and still the same.
From what you have described it is likely that the base station is bricked.
You can check the power adapter by replacing it with another but the Amber power led indication suggests that the base has failed to boot correctly.
Have 4 Arlo Pro cams and had a free subscription. I just went to pull video of an event and to my surprise, no videos, no connectivity, no subscription, no nothing. I thought I was grandfathered in. And I can’t get a hold of anyone in tech support because I don’t have a subscription. Bait and switch? Rage? Yes. Ever buy another Arlo product again? FU(K NO!
Okay - I’m pretty heated about this topic but I shouldn’t have posted my pissy comments. I should have cooled off before posting. Regardless, I’ve removed the VMB4000 hub and one camera from my app. Now I can’t reconnect it to my app. No clue what to do next. Any help would be greatly appreciated. Sure wish Arlo took calls from its customers. My HW may be end of life, but still, I shouldn’t have posted be able to keep using it for free. Thanks.
Removing the hub wasn't needed to restore operation - removing one camera and readding it would have been enough.
Unfortunately several folks have reported that they are unable to add the VMB4000 to their account. None of the hubs are EoL, so that of course should be working. I'm tagging the mods - @BrookeN , @JamesC , @ShayneS - to see if they can help.
I have an Arlo base station (VMB4000) and had 3 Arlo Pro 5S 2K connected to it. I bought 3 new Arlo Pro 5S 2K but I can't add them to the base. I deleted one of the 3 that I had connected and now I can't reconnect to it.
When I try to sync the base and the camera, they apparently sync but I don't see it in the app. Do you have a solution for this problem?
I don't want to factory reset the base for fear that I won't be able to connect the cameras that I already have connected.
My VB5000 also appears to have given up the ghost. With a reset it will flash amber for a few seconds and then go to solid amber. I don't think the 5000 is more than a year old. My VMB4000 lasted about 18 months. Rather than fight my way through support I bought a 4540 through Amazon which will be delivered tomorrow. I suppose these are just consumable devices.
FWIW, I've not had any of my bases fail.
When the replacement arrives, begin by connecting VMB4540 power adapter to the VMB5000 and see if that works.
Will do, but it is getting power at least to the front light that is amber.
Unfortunately, that doesn't mean it's CORRECT power. The use of the old supply will also help determine if it's actually the failure of the hub.
It appears as if I have a similar issue with my VMB4000.
I installed a new wifi router and it will not connect to the internet. I did the re-set procedure and now I only get one amber light on the Power LED, as if it is booting, but it does not change from there except to occasionally flash green on the camera LED (?) but it only goes on for an instant, then back to one amber Power LED.
Got onto the app but it will not find the base station. I checked the internet cable and it is good.
Follow up on the VMB4000 can't connect issue- I also removed all devices on the app.
Just a minute ago all 3 lights went green for about 2 seconds- then back to one amber Power LED only.
An amber Power LED is a problem. It could be the base itself or the power supply. You can check the power supply with a voltmeter to verify it's supplying 12 volts DC. If that isn't true, nothing is going to work.
