New VMB4000 base station. When I try to add it in the app or using the web, nothing shows up after the search. The lights on the base station are as follows:
Power - solid green
Internet - solid green
Camera(s) - solid amber
I think it may be bad. The camera light shouldn't be solid amber with no cameras added, should it? Any ideas?
Lou
Best answers
The issues you're experiencing could be due to a hardware issue. We ask that you reach out to support for more information. You can get to support by going within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing. If by chance you do not have a subscription and are unable to reach out to support please send me a dm and I will create a ticket for you. You send a dm by clicking on the envelope icon on the top right of the forum page.
From your description it would suggest that the base station has failed. The power led should remain green unless the base is having issues with booting up.
There is a possibility that the dc power adapter attached to the base is faulty instead and causing the Base fail behaviour, suggest you risk buy and swap it out for a compatible adapter unit.
I have the VMB400 base station with two cameras connected. It went offline after a power shutdown in my area and I could not get it connected to the internet again once the power was backup.
The power and camera lights were solid green, but the internet light was amber. So i tried the below steps so far but no luck. I have the base station connected to a Netgear router and I changed the ethernet cable to rule out any issues with cable. All my other devices are connected to the internet via this router.
1. Rebooted the modem, router and base. Internet light was still amber.
2. Removed the device from my arlo account and tried to add it again but it did not work.
3. Reset the base, all lights blinked amber and after a while the power light is green. But internet is amber and so is camera light.
Any help?
The amber Internet LED means it's connected to the router (has an IP address) but can't connect to the servers. This can be any number of things starting with the router but can be an ISP issue or anything else via the Internet. You may want to check with your ISP as well as check settings in the router to see if something is blocking access.
Update. Today, I happened to walk by the Base Station, and it now shows the Power and Camera LEDs to be solid green and the Internet LED is blank (off). Obviously, there is something amiss.
Going to try another Reset to see what happens
Using VMB3000|Arlo Smart Home Security with 5 Arlo Pro Cameras and Solar Panels
That suggests that the ethernet hardware in the base failed. If that is the case, then a reset won't help. That said, it does no harm either, so you might as well try it.
Follow-up to the dilemma with my VMB4000 going offline, failing to connect to the Internet, etc.
Since my last post from several days ago, I've left the Base Station powered off, but having had the time today to revisit the issue. This time, I fired up Wireshark (a network packet capture software program if you're unfamiliar) to look to see what the Base Station is doing when it's powered on.
It reflected the Base Station requesting an IP address from the local DHCP server. Once assigned, it began communicating with the local DNS server to resolve a number of records associated with arlo.com, etc. Minutes later, all three LEDs were solid green.
I have no idea what changed, but the issue appears to be resolved.
I am trying to setup a new Arlo VMB4000 base station. I have synced an Arlo Pro2 VMC4030 camera and base station using the sync buttons. All 3 lights on the front of VMB4000 are green but when trying to onboard the base station using Arlo App OR my.arlo.com it can not find the base station. Base station is broadcasting a WIFI signal named NTGR_VMB_xxxxxxxxxx. My router shows VMB4000 has acquired an IP address from the router. Everything is on the same subnet. Base station has been reset to factory defaults using the reset hole in the back, held for 15 seconds. My phone and base station are connected to the WIFI router on 2.4GHZ. Main router, VMB4000 and smartphone/computer are all within 4ft of each other. WIFI SSID is netgear2. Please help.
If you’re new Base has been previously used by another user account and was not removed from that account then it can’t be added to another account.
To perform a factory reset of the base you need to press and hold the rear reset button using the paper clip until the base LEDs begin flashing Amber.
The base should restore with green, green, Amber to show it is ready to be claimed by an account.
Thank you for your reply. Base station has been reset to factory defaults using the reset hole in the back, held for 15 seconds. The lights are now GREEN GREEN OFF (no color). The base station should now be able to be added. But it cannot be added. Error msg is "no base station found"
As @DannyBearAgain said, if this is a used base then it can only be added to your account if the previous owner removed it from their account. It'd be useful to know if that is a possibility here.
This is a new base station. Never used and never installed by anyone else. It came with two new Arlo Pro2 camera. Everything was factory sealed. I know Arlo Pro 2 camera has not been made for a few years, but this kit was never used or installed.
AFAIK, the 3rd LED on the right is a sync signal showing camera and base station have synced. It is not intended to show base station is ready to be onboarded?
Although this base station has never been installed before, can someone from Arlo support confirm that a previously installed base station that was not removed by the previous owner, cannot be activated by a new user. I see too many users are reporting the same problem in varying forms. I though resetting the unit using the reset button in the back erased all prior configurations such as an IP address etc.
While I am not a arlo person I am aware of how the base behaves relating to the led behaviour.
While the arlo documentation does not specify the need for the camera led to show amber post a factory reset my own observations are that the base cannot be added to an account unless the camera led is illuminated with a Amber colour.
Arlo has previously highlighted a cause for the inability to add stale base stations due to the base not being updated to a newer firmware version which can’t be achieved without it being attached to a mobile account.
Thank you @DannyBearAgain . The unit is broadcasting a WIFI signal that is password encrypted by Arlo. Unfortunately, there is no way to log into the base station to see what firmware version it is running. My guess is the first released version. I have a lot of experience with Netgear routers and repeaters. Many of the factory sealed repeaters that had the original firmware had issues connecting to the main router or maintaining connection until they were updated to the latest version. Netgear repeater WIFI signal is not password protected. This base station may be suffering from the same old firmware issue in addition to the 3rd LED not lighting up orange.
Yes, unfortunately there is no way to tell. It would be nice if you could see the firmware somehow after a factory reset (before the hub is added to an account). Or maybe put a removable label on the hub identifying the firmware it shipped with.
I don't think that's the issue here. If you look at your router's attached device list, you should see the hub in the list.
I think over time they've modified the install, and the app is expecting responses that it isn't getting.
Hopefully @BrookeN can help.
I have 6 cameras from each generation. I have two Arlo Pro (original) and they were working just fine until the latest update to the base station. I am ticked. I called support and OF COURSE they will not tell me why the cameras are not working since I took them down to charge them. They will not support their cameras. I DON'T CARE if they are older versions! They still should work to record. I want to know if anyone has a way to get them back to where they are working! I have done every troubleshooting step there is known. Battery is charged, bought a new battery. Took down my other ARLO PRO (original) that was working at the time - put in the other camera, and it worked, but then went from working to OFFLINE and I don't have the ability to toggle it back on! ARLO does not have the right to make it unfunctional. That would be like APPLE or SAMSUNG making your phone stop working just because they want you to buy a new one. You know, when apple got caught messing with the batteries to get you to buy a new phone??? Sound familiar. This has got to be illegal. Please help - anyone because the SUPPORT team is worthless. They send me an article that was absolutely NO HELP. I have removed the battery, waited, put it back in, removed device, added device, then it will work, then it goes back to OFFLINE. My second arlo pro is now doing the same thing but yet it was working when it up on the house! So, after I bring it in, and charge it, then put it in another camera, then check for updates on the base station - it stopped working as well. THAT IS THE ARLO system doing something to my camera, so it won't work anymore. You know - the free recording ones that THEY will no longer support!!!!!! False advertisement as well. "Buy our cameras, you can record for free, but oh wait, when we are not making enough money, we are going to cut off your device and make it so it won't work. Then any new camera you have to purchase - you have to subscribe to monitoring for them to work like your other cameras!!!!" Anyone with a work around to get these two cameras back working as they were yesterday, would be a great help!
I had a working pro2 system vbm4000 base. We had a power outage. When power came back on, system was dead.
System was on a power surge protector. Took unit to Geek squad and they said it was all dead. Bought a new old stock unit (vmb4000) with a new power supply. Tried the power supply on the old unit and it powered up. But the period of 1 week down, it was not recognized by the app. I removed the old unit from the app and have been trying to setup the new unit. Still not being recognized. I am stuck with out system now. Help
Have you checked the voltage from the power supplies using a voltmeter? SHould be 12 volts DC.
Same here. Cannot get my pro cams to sink. 6 hours, 2 days free time waisted. Sucks! That is ok. Been thinking of losing the bill anyway. Without the pro's working I am now only running 4 cams so can save $300 and move to the free plan.
The new unit powers up, lights up correctly. App will not recognize unit. I have tried with both my desktop PC and a mobile phone. Tried a reset and nothing. Is it possible the "New base is faulty" ?
The "new" unit may have old enough firmware that isn't recognized by current software. There's no way to manually update the firmware so a SmartHub (VMB4540 or 5000) would be a better solution.
When I connect my base station to the app it gives me erro #0001 can not update firmware
Unable to update firmware. Support says it’s a known issue, they’ll leave my ticket open and I’ll receive an email once this is resolved.
Has anyone had any success getting this to work? I’ve don’t all the basics: resetting, removing, restarting, etc etc etc. Nada and no help from them.
