New VMB4000 base station. When I try to add it in the app or using the web, nothing shows up after the search. The lights on the base station are as follows:
Power - solid green
Internet - solid green
Camera(s) - solid amber
I think it may be bad. The camera light shouldn't be solid amber with no cameras added, should it? Any ideas?
Lou
Best answers
The issues you're experiencing could be due to a hardware issue. We ask that you reach out to support for more information. You can get to support by going within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the behavior you are seeing. If by chance you do not have a subscription and are unable to reach out to support please send me a dm and I will create a ticket for you. You send a dm by clicking on the envelope icon on the top right of the forum page.
My brother gifted me his vmb4000 base and 3 arlo pro cameras to setup in my remote house in the mountains.
I am there now and have been trying to set it up for DAYS!
its vmb4000 with three lights.
power is solid green
internet is solid green
even camera is solid green (which is not required to add to my app)
The app cannot find the base station. I have been trying for days, have reset multiple times but no avail
I have read that if the unit is binded to another account it cannot be binded again before that account unbinds it. My brother doesn't remember binding it to his account and actually doesn't really want to bother with it.
I have been trying to get ahold of arlo support but I can't contact live agent either through chat neither through phone. I have sent an email and it bounced as well.
SO HOW DO I HAVE THE SUPPORT TEAM UNBIND THIS? This is a 800$ worth system thats practically brick now and it makes me mad!
This is the only place I can get ahold of some people in tech support (I hope) so please reply and help
THE PROBLEM IS; I need to leave tomorrow and I need this done today. So PLEASE reply and help me as soon as possible
Since the Camera LED is green you either didn't reset it properly or the base is faulty. To reset, hold the button for >10 seconds, until the LEDs flash amber. Let the base reboot (~2 minutes), verify the Camera LED is off or solid amber and try adding it again.
No, I did reset it correctly. I synced the camera via sync buttons later, without the app.
The base CAN be faulty, but I have NO IDEA.
I need to contact support (which I can't in any way.. This is the WORST support I've seen all my life, no exaggeration...) to know if its binded to another account, and unbind it if it is
This really is stupid
Your brother needs to log into his Arlo account then, remove the cameras and base station from it, then you need to reset everything (not just the base station) and add to your account. That's assuming that everything is working correctly otherwise.
It's not linked to his account neither. Maybe to one of his children or someone else
He doesn't want to bother with it. He can "verify" a mail if he's sent one but he won't hassle like I do.
Can we at lease see which account it is binded to?
Arlo doesn't provide that kind of information, as it's be a breach of their customers' security. So, your only way forward is to ensure that your bother had removed them from the account, providing that everything else works ok, or to get a completely new system.
The first hurdle is getting the base added to your account. If the base is factory reset successfully then the camera led should be illuminated constant Amber which indicates that the base is ready to be added to an account.
Arlo does have a problem adding older base stations with earlier base firmware using the new app unfortunately so this is likely the main reason for your difficulty.
Thank you for the answer.
I don't think he would have joined anyone's drawer because he has been in his box since 2018 and has been tested for the first time now.
The reboot you wrote was done several times (pressed on the reset button until all LEDs blink yellow), which did not solve the problem.
If the device was logged into someone's account, HARD RESET would have solved the problem.
>If the device was logged into >someone's account, HARD RESET >would have solved the problem.
Unfortunately not.
Thank you for the answer,
As I wrote, the device is not logged in to any account because it was purchased in 2018 and is now used for the first time!
I have proof of ownership, I don't understand what you're talking about really. So if i forget which account I registered my system, I need to buy a new 800$ system?
The system hasn't been used for a long time, so you can be correct. And as I've seen there is no way to update the firmware without adding it to account as well?
So, I can't contact customer support, I can't add it to my account, so it's pratictically brick at this point?
There have been suggestions that very old firmware is now incompatible with the current setup needs. If you can't onboard the base in the first place, there's no way to update the firmware. The only choice would be to buy a new SmartHub, either the VMB4540 or 5000.
I have a VMB 4000 base with 4 Pro cameras attached.
I bought an Essential2 camera for the system but can not get it attached.
The ' Add a Device ' does not light up on my app.
I am using version 6.2.2 (9759)
Released Jun 30, 2025
any ides?
thanks
Not sure if you tried resetting to factory defaults by holding the reset button for about 30-40 seconds. This is what restored mine to factory settings. The 10-15 seconds only reset mine. Although it didn’t solve my issue. Best of luck w this junk.
@Enterprise_J I already reached out to you regarding your base station.
I have the same problem!
@PalFam Please follow the steps that were within the post.
The Essential 2nd gen still will not connect to my VMB4000 base station. All firmware is updated and it will not connect to the base station so the problem is not solved. When trying to connect to the base station in the app it say's camera failed to connect Error code 65535.
I been trying for a couple years to get this to work and no luck yet and thought maybe Arlo would have fixed the problem by now. So should I just throw it in the trash?
Well, that's a bit of an overreaction since the camera can just connect to your WiFi. However, if you're trying to use local recordings, it must connect to the base. Of course, then there's the issue of not being able to use the app to view the recordings.
I suppose your issue is like that of others here that have been having various issues when trying to use a VMB4000. My guess is that it trickles down from Arlo supporting newer hardware in ways that cause issues with legacy devices, even when they are not EOL (cameras are EOL but not bases).
There are 2 things that pop to mind that may work:
1) If still using the old interface that uses Library to view recordings, migrate to the new interface that uses Feed. There are issues around this migration like custom modes not migrating but this may help (or not).
2) Buy a SmartHub (VMB4540 or 5000) and replace the existing base. That means removing all devices connected to the base and then adding the new hub followed by the cameras.
Tried to add three old Arlo Pro VMC4030 cameras and another VMB4000 base station. It automatically updated Firmware on the hubs through the app. When I tried to troubleshoot per Arlo guides, which meant now removing cameras I lost my other 2 original cameras in the app. Went for full reset and now lost a smart hub that no longer connects. I can see the cameras appearing to sync by the green light on the one surviving hub and the camera responding with rapid blue blinking as it was interfacing?
Anyway, so disappointed in the lack of support in the guides and forums. Everything was fine and I should have not tried to make my system more robust, ended up with paperweights 😞
Arlo is should be a system we can trust with our security needs and now it seems like it’s possibly about money to force upgrades?? Not sure if others are in the same situation?
I am having this exact same issue and can't get support help, can't get past the AI. Can I get help as well
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
I wonder if my VMB4000 has AI that knows when I'm out of town. It periodically (not often) disconnects from the internet, but usually that's when I'll be gone for a week. I've tested the cable -- perfect. It goes into a separate port on my Sonicwall firewall, whose log indicates no interruptions in the internet connection. Can't test whether the Arlo server is overloaded or not responding, since I'm unable to get the address.
My solution, which is ongoing, is a smart plug to disconnect power for about 10 seconds, then reconnect power. My manual solution, which has never failed, is to turn off the hub for 10 seconds, then turn back on, and wait for reconnection. Other posts have indicated that Netgear has built in this inability to reconnect without a power recycle. This inability is the new look in security?
Not sure what has all of sudden happened, but my Arlo Base Station has been sitting on the kitchen countertop for seven years, providing connectivity to five Arlo Pro cameras.
Recently, beginning July 24th, I discovered the Arlo Base Station is no longer able to connect to the Internet. Not sure what would have caused this, but power-cycling the device repeatedly didn't help. Nor did swapping the Ethernet cable. I know it's not an issue within my home network, because all of other devices can connect to the Internet without issue.
FWIW after it's powered on, the three lights show green, then the 1st light (power) changes to amber the other two (Internet and Camera) switch off. The 1st light remains solid amber. I suspect performing a reset of the base station is the next step?
Update: Performing a reset doesn't appear to do anything. IOW pressing the reset button on the back for ten or so seconds is supposed to force a reset with the lights flashing, etc. In my case, pressing the reset button did none of this. Even pressing it for thirty seconds results in no flashing of lights, meaning the 1st light remains solid amber.
Reviewing my.arlo.com reflects the Base Station to be running Firmware 1.27.0.0_4732_03495c2 (released May 1, 2025).
Using VMB3000|Arlo Smart Home Security with 5 Arlo Pro Cameras and Solar Panels
