Or does it have to be with network cables to the hub/switch/router on the network?
Thank you in advance.
Hello Ant,
Good question! Let me see if I can explain the answer so it makes sense. The Arlo Base Stations will be connected to your account. They do communicate with the cameras through WiFi but they will not be connected together. You can use the Base Stations to extend your Arlo System. But in any case you will need to have an Ethernet cord running from both Arlo Base Stations to your Hub/Switch/Router which ever one you are using, and the cameras will be synced to their respective Base Stations. If one Base Station stops working then only the cameras associated with that base station will be effected. Hopefully this answered your question. Please let me know if you have any more questions.
The Arlo Team
David S.
Hello Ant,
The Arlo Team
David S.
David_NG wrote:Hello Ant,
The Arlo Team
David S.
Thanks. 🙂
Can one continue to use the basic (free) plan if you have two basestations, but are still under the limit of 5 cameras in total. I'd like to have three cameras on one base station and two cameras on another, but still use the basic plan.
Thanks.
dase wrote:Can one continue to use the basic (free) plan if you have two basestations, but are still under the limit of 5 cameras in total. I'd like to have three cameras on one base station and two cameras on another, but still use the basic plan.
Thanks.
According to https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-... , I don't think you can even have two base stations on the free plan. 😞
Yeah, that's what I figured. Oh well. Seems like a restriction that should be lifted as long as you stay under the total camera limit. I have a lot of area to cover and having two base stations would really help. I'll file a feature request.
dase wrote:Yeah, that's what I figured. Oh well. Seems like a restriction that should be lifted as long as you stay under the total camera limit. I have a lot of area to cover and having two base stations would really help. I'll file a feature request.
I agree. Please be sure to post your URL so we can vote it. 😉
fekt wrote:
We should be allowed to have 2 base stations, with max 5 cameras on each. We have paid for both stations. Why do we need to upgrade our plan to have this?
You can have two bases... but you must set up to two different accounts/emails if you want the free service plan ( as they free plan limits to 5 cams/ 1 base )
same here. I just urchased & installed & found out that I can't put 2 cameras where I want them. So even with 2 cams, I would need to base stations. & netgear would want me to pay 10$/mo for this? no way, I'd rather return it
Huh? The number of base stations has no bearing on the free plan, only the total number of cameras per account.
As long as you keep the number of cameras to 5 or less, you can use the free plan regardless of the number of bases and where they're placed. If you exceed 5 cameras, you can still use the free plan by creating a second account with at least one base and 5 or fewer cameras, just as with the first setup. Use Settings, Grant Access on one account and invite the other account's email address. Once accepted, all cameras/bases will show up in one login. It's not quite the same as logging in with the master account but it's close for most purposes.
I'm not clear on what you're asking but you can certainly use multiple base stations in multiple locations using one login. The big issue is the total number of cameras. If you want to stay on the free plan, use a second email address for the second location and then use Settings, Grant Access to view both setups using one login.
