Camera unable to Sync and Doesn't Blink Blue
Hello,
One of my cameras synced just fine, blinked blue slowly and then blinked rapidly and synced successfully. However, the second camera did not blink blue at all when I pressed sync. It seems that it's not a battery problem, because it did flash once blue when I inserted the batteries. But it doesn't flash at all when trying to sync... Any help?
Honestly, I would first pull the batteries out of the cam and redo ( making sure they're in right, like the label inside shows ).
Watch the switch of the front row to back re placement of batteries
If it fails to sync then i would try a power down/up of the base unit and watch what the three leds on the base are doing/do.
Could be dead batteries - try a fresh set.
Spoke to the technical support team over the phone and it's a hardware issue so they will replace the camera.
Colyogurt,
What problem are you seeing? Could you provide more details on the issue?
problem resolved...embarassed to share fix
Colyogurt,
Glad to hear the issue is resolved! Don't hesitate to post if you have additional questions.
