  • 8 Replies
  • 21142 Views
  • 6 In Conversation
ArloParlo
Hello,
One of my cameras synced just fine, blinked blue slowly and then blinked rapidly and synced successfully. However, the second camera did not blink blue at all when I pressed sync. It seems that it's not a battery problem, because it did flash once blue when I inserted the batteries. But it doesn't flash at all when trying to sync... Any help?
8 REPLIES 8
Honestly, I would first pull the batteries out of the cam and redo ( making sure they're in right, like the label inside shows ).
Watch the switch of the front row to back re placement of batteries
If it fails to sync then i would try a power down/up of the base unit and watch what the three leds on the base are doing/do.
Afifiah1
I do have the same issue, the camera was working perfectly tomorrow, today I received a notification that there is an issue with connection so I took off the batteries restarted the system and nothing for the camera (one blue blink then nothing) I have 3 cameras and the other two are working perfectly.
Could be dead batteries - try a fresh set.
Afifiah1
Spoke to the technical support team over the phone and it's a hardware issue so they will replace the camera.
Colyogurt
I'm really disappointed that this highly rated security camera doesn't work at all.
Colyogurt,
What problem are you seeing? Could you provide more details on the issue?
Colyogurt
problem resolved...embarassed to share fix
Colyogurt,
Glad to hear the issue is resolved! Don't hesitate to post if you have additional questions.
