Shjm73,
Try removing the camera, bringing the camera close to the base station, install a fresh set of batteries and then resync. Allow the camera to (temporarily) remain near the base station overnight and see if you still do not receive the update.
Same issue here...ben on hold with Customer support for 20 mins now , I am the 8th person in the Queue..
Shjm73, AngSuro
Have you tried inserting a fresh set of batteries? If the batteries are low, this can cause the firmware update to fail.
Well that doesn’t do much for me. Thanks for the info. Had mine about 7 months and I’m not paying to talk on the phone. Have no way to get a hold of support. Stupid way to do business in my opinion!!
Tried all recommendations listed above. Netgear needs real developers. Update script never prompted to save previous version, so we are screwed. Total waste of money.
Can we go back to previous firmware version 1.2.16720? Firmware1.2..21616 sucks! having truble with all cameras.
Please queue previous firmware and send note to all usrs, so perhaps our systems will work again, otherwise this **bleep** is going into the trash. I will never buy any Netgear crap again!!!!
Hi Shjm73,
i just removed all devices, including base station. After rebooting my router, I re-added base unit and 2 of my 4 cameras which are working so far with no firmware msgs. The other 2 cameras fail to add, even with fresh batteries, so i'm assuming they have expired, although lights flash during sync process. I ordered 1 new camera and 3 Silicone Skins. These cameras are sensitive to UV and both were outdoor cameras in direct sun. This will be my last purchase. Batteries don't last long and arlo products are over-priced. Will invest in A/C powered cameras with DVR. The price of these systems are comming down and are better quality.
hope this helps
My cameras are almost all directly exposed to long periods of sun. They are not UV-sensitive. I have various camera models (original, Pro 1, Pro 2) and none have had these issues.
If opening and closing he battery door as well as rebooting the base doesn't help, remove the camera from Settings, My Devices and resync. Any better?
Hardly widespread but there are a number of similar cases. The best answer is to use the Contact Support link at the bottom here and again on the new page for a possible RMA.
Firmware update in progressI have the same issue my device is stuck for a couple of weeks now. It appears to be a wide spread issue and there is no easy way to contact support.
Use the Contact Support link at the bottom here and again on the new page. The third page will have options for chat or phone.
Shjm73,
Do to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
I am having the same problem with 2 of my camera's. I have attempted to get help for support to no avail. I have read all the discussions, I have just wasted hours for 2 days on this. This is rediculous as mine are not that old. Why would you make it impossible to get help, unless these are defective. I would appreciate an answer ASAP. I have been haveing this problem for months, but just now had the time to work on them. I feel that for the price I should not have to go thru this.
@ShayneS wrote:
Shjm73,
I would like a response as well!!!!
