Camera's keep going offline
FYI when you Wikipedia AP you get advanced placement. Im very familiar with what a wireless access point is.. The contributor used the term AP..since many of the folks here are new to wireless accessories...it might be advantageous to define terms if they are going to abbreviate them in order to avoid further confusion and stay on topic..it's nice to sound smart but we're here to help or so I thought..
Keyrain,
What is the behavior of the internet LED on the base station when you see this error message? Do you see this error on the web browser as well? What device/OS version are you using that is producing the error message?
There's no problem checking it from the laptop. This issue started when the app was updated.
Keyrain,
What is the iOS version on your phone? Are you running any kind of security apps on the phone?
Arlo system has been working great until today. The system has been coming online and offline a lot. Performed a power cycle on the base station with no luck. Any suggestions?
Is this only on just the app or browser - have you tried the other? Are videos being recorded?
Use the power switch? Unplugging does the same thing.
Not a common occurance but happens from time to time. First, when having an issue, what are the LEDs on the base showing? Should be the left 3 on and green.
That means all the cameras have disconnected which could be communication issues between them and the base (distance and/or interference) or perhaps a bad base. Contact support using the Support link at the top here.
*right not tight
No one is saying you can't use other WiFi or wireless devices with Arlo - I have 12 WiFi devices in use right now with no issues. That doesn't mean that placement isn't a possibility or that you happen to have some bad hardware. One thing to try, if possible, would be to move the base to another centrally-located room so that WiFi interference is minimized. You can do this inexpensively using a long Ethernet cable temporarily or, more expensive, a WiFi extender with an Ethernet port.
You can also use some like HeatMapper (http://www.ekahau.com/wifidesign/ekahau-heatmapper) to map out signals and strength in your house if you're technically inclined. It can be illuminating to see how signals map out around your house.
Arlo creates its own WiFi network which may well interfere with, or be interfered by, other networks. Sometimes a bit of trial and error is in order - one size doesn't fit all.
And then there's the possibility that it's just a bad base which only contacting support using the Support link above may bring to a resolution.
Tagtekin,
There could be an interference issue causing the camera to drop. Consider (temporarily) relocating the base station/camera so that they are closer together to see if you get the same behavior.
