I have been trying to view my cameras all day from my work computer and my Android phone. The camera images are "stuck" on yesterday. I tried going in to settings online to restart the base station, but it says "your camera is busy and cannot restart." How can I fix this?
Did you try the app using cell service rather than WiFi?
You may need to manually power cycle the base when you get a chance.
hochartz,
Are you not able to live stream the cameras? Live streaming should update the image. If not, I agree with jguerdat above, consider rebooting your base station (using the on-off button) along with power cycling the affected cameras by opening and closing the battery compartment door. Are you still seeing this behavior?
