I have one of my cameras that is duplicated (listed twice) in my mode section. How do I remove one of them. I've tried editing both to identical settings but the motion detection is not working. I'm thinking it is due to the camera being listed twice and having two sets of settings for the same camera. I can't find any way to remove one of them in modes only removing the camera entirely.
This issue has been resolved in iOS app version 2.3.2 please visit the app store and update your Arlo mobile app to this latest version.
To remove one, Goto SETTINGS, pick camera, go to bottom of page, REMOVE DEVICE
The camera is only listed once under settings. It's not duplicated there, it's only duplicated under the modes screen. If I remove it from the settings screen will it remove both from the modes screen and then I just have to readd it?
If you REMOVE DEVICE, it should also remove it from the modes
Any fix to this yet?
I got the same thing twice now my first 2 days in a row of using them.
Day 1:
3 cameras duplicated to 6.
Tried logging in/out, resetting, etc. Nothing worked.
Deleted them all and started all over.
Day 2:
3 cameras duplicated to 6, very annoying.
Logged in/out and this worked and back to the 3.
Guessing some type of bug.
This issue is currently under investigation by the engineering team. I will post an update as soon as I have more information. We appreciate your patience in this process.
I’m having the same issue. I’ve tried deleting the app off my phone and also deleted/reinstalled all the cameras. It worked for about 12 hours and then all cameras started to show a duplicate screen again. Hoping the Netgear team sorts this out in a timely manner.
Whatever they did with the update it really messes things up.
This issue is still being investigated by the engineering team. Please do not attempt to remove the duplicate cameras as this does not resolve the issue. Some users have reported having success by uninstalling the Arlo mobile app and downloading a fresh version from the app store. I will post an update when I have more information.
We apologize for any inconvenience this may cause and thank you for your patience,
