Répondre
Statistiques de discussion
  • 13 réponses
  • 3682 visites
  • 1 compliment
  • 5 en conversation
Fdona
Hi
after release 22.09.22. My base vmb4000 don’t want work , I cannot see and connect the base and all my camera so
all the 3 light are green
did somebody have the answear
thank
mail.    Francois@donabella.fr
13 RÉPONSES 13
All 3 LEDs being green implies the base is working. Have you rebooted your base? Have you tried both the app and web client to see if there's a difference?
Fdona
Yes i did
try with my pc windows and with my iphone and dont work again
i reboot again and nothing
can you help me?
You might need to reset the base and onboard everything again.
Fdona
Ok
but if i reset , i will lost all my configuration
i have 22 basic camero connected with 10 scenario !!!
a lot of work
i cannot save somewhere my acutal configuration??
Yanick2112
Ne fait aucun reset j’ai essayer et sa fonctionne pas plus j’ai exactement le même problème que vous
Fdona
Je pense que la derniere release du 22/9 a un bug
que faire
Yanick2112
J’ai passer ja journée avec un technicien arlo et il m’a fait refaire les mêmes étapes toutes la journée pour un résultat négatif j’ai hâte de ravoir accès à mon ensemble qui m’a coûté très cher
Yanick2112
issue was solved!
After many many attempts trying to resolve the problem of syncing, I got a Hub replacement today and installed it. Everything worked great, straight forward like the first time. Somehow was difficult for us to find the issue because the Hub seemed to operate normally (led light flashing accordingly to setup, restarting, reseting etc) but no communication between cameras and the base.
Thanks to Fardeen from customer service, which has been very patient with my case, we lost a few days trying to solve this. Thank you again, if anyone can show this to I would appreciate.
jai. Trouver sa sur le forum
PaulaB0
Bonjour @Fdona,
Je vous prie de contacter notre support technique afin d'obtenir de l'aide de nos experts. Vous pouvez le faire par téléphone, live chat ou en ouvrant le dossier en ligne. 🙂
@Yanick2112, est-ce que vous pouvez m'envoyer un numéro de dossier par message privé ? Je voudrais le consulter avec notre support technique. 🙂
Bonne journée,
Paula
Équipe Arlo
Yanick2112
Fdona
Hello
i reset the base yesterday and all work today
but i was obliged to reconfigurate each cameras (20)🤪🤪 and all scenarios
not thank you to arlo, i lost a day !!!
Yanick2112
reset my base and  all cam no sync help me
PaulaB0
Bonjour à tous,
@Fdona, merci pour votre retour. Je suis ravie de savoir que tout fonctionne correctement maintenant !
@Yanick2112, je vais vous contacter par message privé.
Bonne journée,
Paula
Équipe Arlo
