hello,
my my base station has been showing as offline for the past few hours and I'm currently out of town so I can't find out what's wrong with the equipment. But I know internet is working fine at home. Could it be an Arlo system/cloud issue? Would if be possible for Arlo support to find out what's happening?
Thanks!
Hannah
I had the exact same problem! Same Amber light on for Internet and after app update. I restarted my base station and everything's good now.
Hannah
HannahX,
Do you have any way of finding out what the internet LED behavior is on the base station? Do you know if there was a power outage at the location in which the base station is setup?
I don't know about the LED behaviour, but I know Internets been working fine this whole time, and I even got a movement detected notification and a video downloaded just a few minutes ago. However all cameras and base station are showing as offline on my iPhone app. What are the possible problems? Does this need to wait for myself to get home to get resolved?
Thanks!
Hannah
Hannah
Sorry I couldn't help you more.. You might want to start a new post/ticket so Arlo support can help?
Hannah
edrodgers wrote:
I did thanks for your help. Are you single?
HA! 😄
New software makes Arlo into a dating service... I like it.
takes big ones Ed
Pay attention to your self *******!!
Sometimes we have grownups here. Other times...
