Checking for base station updates possible!
  • 3214 Views
By pure dumb luck (I was posting a reply about firmware versions), I found that you CAN check for firmware updates for the base station.  Go to Settings and choose the base station. Scroll down to the bottom and simply click on the firmware version. It changes to a screen that shows possible update status.
Who knew?
we do now... but other than view it nothing. can stop the update if running base 🙂
BTW, it only works on a browser. Not sure if this action would trigger an update or just view status.
Not sure what good this is now. I had a base station that was on old firmware but clicking on the version told be no new firmware was available. A reboot brought it up to snuff.
