  • 6 Replies
  • 5447 Views
  • 2 Likes
Gizzygone
I just installed an Arlo security system in my house. I have two cameras on the front: one on the left side facing right, and one on the right side facing left.
Motion capture seems to be very inconsistent: even with moving the cameras and messing with sensitivity:
My garage mounted camera, facing left, does a decent job, although cars are halfway up the driveway before it records (and some recordings start out granulated for a good 3 seconds, so you miss some action).
The house mounted camera stinks: it'll start recording with clouds on the horizon, but a flock of turkeys came by (captured by the garage cam), and it caught nothing. It's mounted in a way that I can't get perfect left to right motion capture, but more of a upper left to lower right motion.
Any suggestions?
The garage cam has all but 1 bar of signal, the house cam shows full strength.
6 REPLIES 6
Gizzygone,
Due to the many variables in each users environment, it can take some trial and error to find the best conditions for your Arlo system.
Take a look at this article outlining best performance tips for optimizing motion detection: Optimizing motion detection performance on Arlo Wire-Free cameras
After you get the false triggers down a bit ( try and not to cover to much area at one time ) you might consider using a dual trigger for  2 cams.
rules;
Cam A detects / records on A
Cam A detects / records on B
Cam B detects / records on B
Cam B detects / records on A
you get 2 recordings, one from each side
Gizzygone
I didn't realize this was an option: I set it up, but I still don't get consistent recording from the house cam: do the settings on each rule have to match exactly?
No, the record times can be a bit different I would guess ( tho mine are the same )... there are a number of threads on this... just make sure the rules are on in he mode properly.
I label my cams rules like :  Front 1/1, Front 1/2, Front 2/2, Front 2/1
Thats so when I look at the rule I know the cam and what it's doing ...
Gizzygone
Looks like the new app update killed my rules? I can't seem to add a new rule so that it records both cameras in action?
Gizzygone
Scratch that: you have to make a custom rule for it to work....
