My Arlo has all the sudden stopped working and has a message saying it’s not connected to the internet! My internet is connected and on my hub the lights are lite up saying it’s connected but the app still says it’s not! Can anyone help me with this please?
I’m having the same problem for over a month now. They need to get their act together.
Approximately every 24 hours. Getting sick of getting the ladder out and climing up and down, re syncing etc.
A solution would be much appreciated.
Had system for a couple of weeks and I'm not getting any peace of mind or benifit that a security system should provide.
Camera keep going off line
This is because Arlo is not reliable and it sucks . What a crappy system . You have to reboot the base station and i reconnects then a couple of days later low and behold it happens again , I called tech support and off couse they blame it on my set up, But there is no brick wall between my connection just a window and a full Battery . What a waste of money
I have the wireless free alro camera and it keeps saying offline " what should I do?
I don't know I'm constantly having to take all 4 x Cameras down and resync them. Sometimes a power down of the base and restart works but even then within 24 to 48 hours they're all offline and the power down usually only works once. Then it's get the ladder out, up/down resync then up/down the ladder again putting them all back in place. Been going on for 3 weeks now. Just about ready to return them.
Why do three out of my four Arlo cameras go offline all the time? Device info shows good connection to the base station and good batery level. At home I can re-establish the sync, but on the road I am helpless. I just put in fully charged batteries and all was well. I go to a family visit and they go south. This happens often. What can I do remotely to get them on again?
I have the same problem!
I have been asking if there is a problem with my basestation........
I have checked signal strength at each camera and have good-strong at each location with lots of bandwidth.
I am running 4 Arlo cameras and 1 Arlo Pro 2. The Pro 2 is wired. Any of them will drop and go off-line. Batteries/line power are all strong.. I get them all working by all the usual methods and hours- not days- later one-three will be off-line.
Is the 4th camera staying connected... it's just 3 go out ?
yes.
I'd swap the good camera to one of the other locations to see is the bad issue follows the camera or not
Hi TomMac,
In my case 3 of the 5. The 3 yesterday are a not exactly the same set as yesterday. I have moved camers before and even replaced a couple.
Here is a link to the thread I started last month, but got no response.
https://community.arlo.com/t5/Arlo/Arlo-basestation-issue/td-p/1713147
This may be a temp fix...just like re-syncing to the base. But this is NOT a long term solution as with new baterries the issue reoccurs. I have 9 cameras and 1/2 are offline most of the time due to forced software upgrade pushes.
HW: VMB3010r2
Firmware: 1.12.2.4_2772
