Arlo Geofencing does not work
I have geo-fencing enabled such that when I am within the radius, the system should be disarmed. When I get home, the app notifies me that I have entered the geo-fencing area, yet the cameras will still notify me that they detect motion. Broken.
Did you specify what Arlo should do when you're in Home Mode and Away mode?
The last fewdays the arlo app will not switch from disarm to arm when I leave my house?? Any suggestions?
Engineering is currently aware of and investigating an issue with Geofencing that is affecting some users. I will provide an update as soon as I have more information.
I'm having the same problems with geofencing.
Not sure where everyone else is, but I'm in the UK and I'm having this issue too. Will it get fixed through a software update?
I'm in the U.S.A and haveing that same problem... I'm thinking a software Update
Any fix yet?
My Arlo's geofencing also quit working. Going to the setup page shows me sitting at work and the small geofence surrounding my home - several miles distant. I believe the situation started during the last IOS update. One way of fixing the problem is going into my iPhones privacy settings under setup and momentarily shutting off the location services and then turning them back on. Usually after a few seconds, I get a note from Arlo that my Geofencing is now Armed (if I'm out of the zone) or Disarmed (if I'm in the zone). So far this about the only way I have been able to reset geofencing - a royal pain in the a$$! Please fix this quickly.
I have the iPhone X... and after that last update it stopped working.. sometimes it takes along time for it to arm after I leve my home
Here also the same problems after the last app update of arlo my geofencing is not working anymore.
Iphone 7 worked fine always but with the last update doesnt work anymore 😞 is there a fix coming up???
I got arlo because it was the BEST OF THE BEST!! and now it’s just frustrating knowing I have a $200 peice of equertment that douse not do its job like its supposed to.
Latest firmware and app and geofencing stopped working 2 weeks ago.
I have to manually arm/disarm the system
Hi, since ios update my Arlo q geofencing has also stopped working. Is anyone working on this issue or what? there seem to many of us with this problem, yet not one of us has had any feedback. Come on Arlo where are you??????
