Arlo App not recognizing my email
  • 10 Replies
  • 3186 Views
Shane245
Arlo App not recognizing my email but able to log in on Desktop
I have uninstalled and re installed app, same issue
10 REPLIES 10
ShayneS
Hi,
Are you still experiencing this issue? Which version of the Arlo app are you using?
Shane245
version 3.6.1_28445
ShayneS
Can you take a screenshot of the error and PM or attach it here?
Shane245
see attached screenshot
ShayneS
Thanks, I will look in to this and provide an update as soon as possible.
Are you typing in the info or is it automatically populated/copy and paste? If the latter, try typing it - maybe there's a leading or trailing space causing the issue.
Shane245
typing
ShayneS
Can you check if you have a space hiding before or after the email once inputed?
Shane245
No space
ShayneS
HI, can you try and login again, This issue should be resolved. If you still experience the login issue, please remove and reinstall the Arlo app.
