VMC3030 can not factory reset
  • 1 Reply
  • 1916 Views
BYNC
When I go to device on app hit arrow it appears to be trying to find camera. I have tried to factory reset to no avail. Other 2 cameras work fine,
This is the original Arlo camera? (the one that uses 4 CR132 batteries)?
If so, I believe that the published factory reset procedure in the KB article won't actually work with that camera model.  Have you tried removing/reinserting the batteries?
Also, you can sync those cameras w/o using the app.  Have you tried that?
