Arlo App not recognizing my email but able to log in on Desktop
I have uninstalled and re installed app, same issue
Hi,
Are you still experiencing this issue? Which version of the Arlo app are you using?
version 3.6.1_28445
Can you take a screenshot of the error and PM or attach it here?
see attached screenshot
Thanks, I will look in to this and provide an update as soon as possible.
Are you typing in the info or is it automatically populated/copy and paste? If the latter, try typing it - maybe there's a leading or trailing space causing the issue.
typing
Can you check if you have a space hiding before or after the email once inputed?
No space
HI, can you try and login again, This issue should be resolved. If you still experience the login issue, please remove and reinstall the Arlo app.
