  • 3154 Views
Tricatz
Is there an Arlo wireless that will handle the cold?  I would like to not have to take it down in the winter.  The ones I can find only go to about 14 degrees F.
My  Arlo cam and a couple other users I know have gone down to just below 0d F... no problem with operation tho the battery at -10f started to show a lower voltage due to cold
Tricatz
Too bad it won't go lower.  -10F would be a mild winter.  I would need -20 to -30.  Thanks
There have been a few users here with cold temps like that, maybe they'll chime in ( I'll see if i can find the threads ).
As a side note, most outdoor cams in that temp require some form of container and a fan/warm element to prevent problems and condensation.
I'm looking into a container for the Q cam now for winter , the heater is build in as it runs normally warm to touch. 🙂
edit;
found this, maybe you could PM for more info
https://community.netgear.com/t5/Arlo-Wire-Free-camera/Camera-using-outside-temperature/m-p/1034899#...
 Chilly weather here in Finland for the past three weeks, daily lows around -25 celsius and the highs around -10. So far the alro has survived with no noticable malfunctions. Next week's forecast is promising -30 to -40 celsius....
 that's -22f to -40f
