Is there an Arlo wireless that will handle the cold? I would like to not have to take it down in the winter. The ones I can find only go to about 14 degrees F.
My Arlo cam and a couple other users I know have gone down to just below 0d F... no problem with operation tho the battery at -10f started to show a lower voltage due to cold
Too bad it won't go lower. -10F would be a mild winter. I would need -20 to -30. Thanks
There have been a few users here with cold temps like that, maybe they'll chime in ( I'll see if i can find the threads ).
As a side note, most outdoor cams in that temp require some form of container and a fan/warm element to prevent problems and condensation.
I'm looking into a container for the Q cam now for winter , the heater is build in as it runs normally warm to touch. 🙂
edit;
found this, maybe you could PM for more info
2016-01-15 06:45 PM
Chilly weather here in Finland for the past three weeks, daily lows around -25 celsius and the highs around -10. So far the alro has survived with no noticable malfunctions. Next week's forecast is promising -30 to -40 celsius....
