I have an updated my Iphone to IOS 15 and I cannot talk through my doorbell when someone rings the doorbell but if I go to watch live feed I can talk. Did I miss something when setting it up?
Any time someone rings the doorbell, I answer the call on my phone but the person there cannot hear me when I press the button.
Have you tried raising the speaker volume within your doorbell device settings?
Are you on the latest version of the Arlo app 3.5.6? Also, does adjusting the volume for the speaker in the doorbell device settings make a difference?
Does this occur on WIFI and mobile data?
Can you update to iOS 15.0.1 and test again, I am not experiencing this issue as described with a 13 Pro Max with iOS 15. Do you happen to have a 12 Pro max?
Do you have the Auto mute enabled when you answer your call?
Are you connected directly to your router or base station/Smart Hub? are you able to test both options?
Are you both running the latest Arlo app v3.5.6? it was on a planned slow roll out release, so you would need to remove & reinstall the app to receive the update.
I have the latest iOS and app version but on iPhone X.
By chance if you hang up the call and press the doorbell again straight away does the audio then work as that’s what’s happening for me.
I have said to the support team though that doesn’t really help much as a person coming to the door wouldn’t know (or should have to) press the bell a second time after the call has been hung up.
Your right that does work but how is anyone suppose to know that and I’m not going to hang a sign on my front door to say that. Work fine with my wife’s phone but not mine. The support team has been iffy at best just keep getting emails that says try again or what iOS are you using or what version of our app are you using. It’s like no one is taking notes or reading past responses. Might have to switch to Ring or Nest.
i have the same problem. just set up the doorbell. the person at the door can hear me but i can't hear them. the recording records both. i am also not getting live video during the call.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any methods you have previously performed.
all the chat recommendations. talked to someone on phone as well. being elevated to level 2 support.
I've tried everything recommended. Rang it myself and tried to adjust volume. No sound comes out of the doorbell to whoever rings it. It does reply with the voice if you choose an automated message.
ios latest version, 15.0.2
Are you still experiencing this issue?
I also can't make a voice from the doorbell.
iOS15.0.2
Arlo 3.5.8(2878)
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
