  • 2165 Views
Cindi7
the doorbell came w/ the doorbell, mounting plate, and optional side mounting plate.  They packaged the doorbell and mounting plate already assembled and I do not have the strength in my fingers to sperate it.
Is there a trick I should know of to get these apart??
There is a release pin tool in the packaging - a flat metal disk with a wire extension.  You stick that into a release hole on the bottom of the doorbell.
If you can't find the tool, you can use a bent paperclip instead.
Cindi7
THANK YOU SO MUCH - THAT DID THE TRICK!!!!!!
I read that to be a "reset" pin - didnt think to even look to use it for release.
patdaly16
Thank you for the solution.  It would be helpful for those directions to be included in the Quick Start Pamphlet.
  • 2166 Views
