If you haven't done so, create one with a small area which would not be typically be triggered. I set sensitivity to 20 and only detect people.
Maybe i just got lucky!
But it works flawlessly now.
Unless there is a drastic change in the Arlo company, I shall no longer purchase their products. I had a video doorbell at my previous house. I have now moved. I tried to help Arlo solve their problems with the video doorbell, but it seems like the technical staff is totally incompetent. I have given up. I am signing out of the Arlo community and for my new house will seek another solution.
Good luck to you all.
Kind Regards,
-kirk-
Yes, I set up one small zone. Where did you set the sensitivity level ?
Thank you, I found the setting and changed it to 20%. We will see how it works.
I was getting responses (empty promises though they were) after I opened a Better Business Bureau case a couple of weeks ago, but now those have stopped. Arlo simply will not take responsibility for this failed product. Like others in this forum, I have several other cameras (Pro, Pro 2) that work just fine, but this lack of customer service response and lack of accountability from Arlo has soured me completely. They will get no more of my business and I will not go away until I get a refund for this Video Doorbell.
I'm happy to report I've solved this problem with about 30mins of work.
Step1. Remove Arlo video doorbell
Step 2. Install Ring doorbell pro
Step3. Enable zones on ring doorbell
Step 4. Return Arlo
Sorry Arlo, but I gave you many chances.
LOL. I dont really want to switch, so I am hoping this gets resolved. Plus I am past my 30 days...
That said, Arlo has fumbled this product in a major way whereas Ring is leaps ahead in both stability and customer support.
I spoke with a representative a couple days ago and was told that a new backend software rollout is expected within the next day or two. I was walked through a few steps to deactivate then reactivate the doorbell, etc etc and then told to give it a few days and see if any changes are noticeable.
So far, nothing has changed. Getting constant alerts for motion well outside the activity zone with only person selected.
Going to cancel the subscription service if this isn’t resolved by the end of the month and look for alternatives.
So there is new backend software coming out? I wish they would tell us when this is rolling out and I HOPE it resolves the issue. I do not really want to switch to a different brand, because I like the field of view on ARLO. You can see MUCH MORE then other brands of doorbell cameras.
Arlo has told me multiple times over the last 6 months that an update has been released that has solved the issue. No improvement.
i am the original poster on this message thread and it is disapointing that Arlo has not been able to fix this issue as it has been going on for quite some time. Their other products are great, but the video doorbell has had nothing but issues. while arlo is taking their time to fix a feature, is it possible that Arlo can at least waive the monthly fee for a service that is not working?
Improvements have been released for Activity Zone accuracy. More improvements are still being worked on for users continuing to experience issues with Activity Zones.
If you're still experiencing issues, I encourage you to reach out to the Arlo Support Team and open a ticket. You will find several options for contacting support in the provided link.
I have a ticket opened. Nothing has changed with any updates that you keep mentioning.
Thanks...
We’re not looking for “improvements”. We want the activity zone feature to actually function as intended.
The improvements you should be working on are better customer support and finding engineers that can fix this broken product.
Agree, I also get multiple notifications outside of my zones. And also agree that we are paying for a service that is not working.
I have not had any false alarms with the sensitivity set to 20
Seems like the effective zone is twice the size of what you set. So set it accordingly.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
