  • 7 Replies
  • 6023 Views
  • 4 Likes
  • 7 In Conversation
JackShepBoston
We need the ability to rotate the image 90 degrees. Due to the vinyl shingles on the outside of my house, I don’t have a flat surface to mount this to in a vertical configuration. I even tried buying the wedge kits from Ring, but number one, your doorbell doesn’t fit on it and number two, half the doorbell would be hanging off. The simplest solutions for me would be to mount the doorbell horizontally and rotate the image(which you don’t currently allow), or go with a competitor who sells a smaller product that will fit where my existing doorbell is.
7 REPLIES 7
JackShepBoston,
I will pass your feedback along to the development team.
lkalis
Yes, either allow the video to rotate on a horizontal mounting or create different size angled wedges for the camera.
This is what is needed, but more polished than a 3D print
https://www.etsy.com/listing/751704092/arlo-video-doorbell-mount-for-vinyl
pavest
yes, please implement. This features is much needed. Surprised it's not there already. Thanks
erickufo
Hello, I am also asking to please follow up with this request to add the 90 degree image rotation option. Thank you.
newfierick
This rotate ability is badly needed. Any idea if it will ever be added?
Ganged
How is this not an option?  Many doorbells are mounted inside the door frame and not facing outward? Please help. I see that there are such mounting options with other video camera products.
Ganged,
Depending on your environment, you may be able to utilize the included angled mounting option. For more information, take a look here: How do I use the angled mounting wedge that came with my Arlo Video Doorbell?
  • 7 Replies
  • 6024 Views
  • 4 Likes
  • 7 In Conversation
