Is my chime compatible?
Hello, first poster here.
I'm thinking of upgrading the house with several Arlo cameras and a doorbell.
Now, I'm thinking a wired doorbell is the way to go since I allready have a wired "dumb" doorbell.
Thing is though... I have a built in chime/speaker for the doorbell inside the wall behind a flat cover.
I watched the installation video and thought to myself... How will i fit that small white box/module inside behind my flat cover on the wall.
I will upload a few photos so you guys can have a look at what I mean.
Also, installing the wired Arlo doorbell. The thought is that I will be able to utilize the current built in speaker to get the "ding dong" sound from the Arlo doorbell, right?
Current doorbell.
Chime/speaker box.
Inside chime/speaker box.
Inside chime/speaker box zoomed in.
Hard to say. Looking at the last picture, it appears to be an Elko digital chime. Do you see a model number anywhere?
FWIW, the only Elko chime I see on Ring's compatibility list is the plus/RS16. It's is incompatible with Ring - so would be incompatible with Arlo also.
I can't see any other info than the pictures provided, sorry.
I guess it's a bad idea then to go for the wired doorbell in my case.
Maybe I have to go for the battery one and also buy the add on chime thing to put in a wall socket.
Then just live with an extra useless box on the wall 😅
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
