Seems to be a reoccurring issue. I scan QR code, it asks to connect, amber light on chime flashes then white fade & then states it can’t connect. Using updated app on iPhone, doorbell, multiple cameras all work flawlessly???
Best answers
We have a fix for those experiencing issues onboarding their Chime 2 devices. A member of the Arlo development team will be reaching out via email to users who have posted here to coordinate the next steps to resolve this issue. If you do not receive an email within 48 hours, please send me a private message.
Thank you
Thank you for all your feedback. The Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community.
@RuneD77 good luck in getting an answer - It less than two days you will get the standard reply - We're working on a solution. This issue is a joke that should be solved right away. Right now I have two useless chimes and a doorbell that have no where to ring.
Thanks …. I will contact the webshop where I bought the product… it’s quite ridiculous 😂 I’ll let you know if I find a technical solution!!!
I've been going back and forth with support for weeks on this, have shared logs and device details and screencaps. No resolution as yet.
Same issue here with Chime 2
Exactly the same issues as for @CornishRattler when entering the name.
I've tried:
- iPhone 15 Pro (Can't connect to ARLO_xxxx network)
- iPhone 13 (Can connect to ARLO_xxxx network, but fails when you have to name your device)
@ShayneS any updates?
It's a shame that Arlo doesn't care about all customers with this issue.
SOLVED - ISH: I can confirm almost 100% that iPhone 15 pro does NOT work with the chime 2. I tried 2 different chimes, two different iPhones.
i spent almost 3 hours on chat support with 3 different Arlo techs as they walked me through everything I had already done multiple times (deleting app, redownloading app, restarting router, Ect). As I said above, I tried two different chime 2 devices AND two different IPHONE 15 PROs (versions 17.2.1) with no luck.
I switched to my iPad mini 4 from 2015 (running version 15.7.1) and it worked with no issues. Just downloaded the Arlo app, logged in, scanned the chime 2 QR code (off my iPhone since the code doesn’t actually scan from the Arlo app camera) and it setup with no issues.
I wish I had more info on what devices do and do not work but from everything I’ve read IPhone 15 pros do not work at all.
I hope this helps someone down the road that comes to this thread.
Thabks. I’ll try tonight and see if I can make it work- I only have an iPad Pro, but perhaps it will work anyway 👏
It worked for me too. I used an 8 years old iPhone and it finally worked. I've tried iPhone 13 and iPhone 15 Pro. Arlo's software seem to be super poor. Only working on 6-8 years old devices...
I just did the same and now it works 👏👏👏
Have there been any updates on this from the development team?
@gewoldt - Nope - You will get a std. reply that they are working on it, and unless you're willing to buy an old phone you're fu***.
I still have two chrime 2 not working.
Really you should try installing it with an old iPhone… worked for me !!!
After 30 minutes on the phone with Arlo tech support, I was surprised to learn that pairing the Chime 2 with the Arlo Wire-Free doorbell is not possible with the iPhone 15. The representative said they know there are issues installing and pairing Chime 2 using an iPhone 15 and that they are working on a solution. They gave no time estimate for a fix but said I would be sent an email when they have the problem fixed. I am amazed that Arlo has not bothered to deal with this incompatibility issue to date as the iPhone 15 has been available since September of 2023.
Arlo tech support told me that installing and pairing the Chime 2 with the Arlo Wire-Free doorbell is not currently possible if you are using the Arlo app on an iPhone 15. Very frustrating. The tech said she would escalate my issue to the advanced team and I would get an email when the issue is fixed. She gave no time table on when they expect to have the issue fixed.
Hi, as mentioned i used an old iphone to make the installation. That worked fine, and now the device works with my iphone 15 pro max. So my advice - find an old iphone and complete the installation. Probably faster than waiting for the Arloteam to respond 😉
Okay. thanks. My wife has an XS iphone. So l'll try using hers
I thought you'd like a follow up. I was able to get the chime 2 added to my iPhone 15 after over an hour on the phone with an Arlo support tech. The process was so confusing I couldn't possibly explain how it was done.
Hi forum! 👋
I've encountered a persistent issue that seems to affect users of the iPhone 15 Pro, specifically relating to QR code scanning and device connectivity with the Chime unit. I wanted to bring this to your attention for further investigation and potential resolution.
QR Code Scanning Difficulty:
The iPhone 15 Pro is unable to scan QR codes directly. As a workaround, I found it necessary to capture a photo of the QR code using the iPhone, transfer this photo to a MacBook, zoom in on the image, and then attempt the scan again. This method proved successful, but it's far from an ideal solution and indicates a possible issue with the QR code scanning capability on the iPhone 15 Pro.Connection Challenges with Chime Unit:
After managing to scan the QR code, I faced significant challenges trying to connect to the Chime unit. Despite numerous attempts and increasing frustration, I was unable to establish a connection, leading me to abandon the effort for that day...Workaround Success with Alternative Device:
Further investigation into this issue, prompted by discussions on this forum, revealed that several users with the iPhone 15 Pro have encountered similar problems. When I attempted the same process using a Samsung Flip 5 (my work phone), the connection was established immediately without any issues.
This pattern of issues suggests there may be a compatibility or software-related problem specific to the iPhone 15 Pro. I recommend conducting a thorough investigation into the QR code scanning functionality and connectivity protocols on the iPhone 15 Pro. Addressing this issue could significantly improve the user experience for those facing similar problems.
Thank you Arlo for your attention to this matter, and I look forward to your response and a resolution to this issue.
And for all of you that face the same issues, try on a different phone then iPhone 15/-15 pro.
Hi there, for some reason despite many many attempts I cannot are the #Arlo as a devices
1. The provided steps are not detailed enough as I see a different behavior as I try to add the Chime 2. When I am choosing the WiFi network there is some Arlo network coming up which I have no password for.
2. The #Chime flashes and orange light. I have two Chimes and they behave the same.
How can I get this working?
The chime provides an open WiFi connection you have to connect to briefly so you can pass your home WiFi SSID and password to the chime so it can connect. This FAQ may help:
https://kb.arlo.com/000062736/How-do-I-install-my-Arlo-Chime-or-Chime-2
Dear Arlo team,
Could you please write down the steps, which SchapRetr mentioned?
I am having the same issues with my iPhone 15 pro.
Thanks.
I have exactly the same problem using an iPhone 15 pro max. The chime has previously worked but I can no longer connect. the system set up has not changed
I had the same problem with iPhone 15 Pro Max(ios 17.2.1). I tried iPhone 15 Pro(ios 17.3.1), the same problem. I chose iPhone 14 (ios 17.3.1) and this time was successful!
same issue as all the rest my chime2 wont connect. have doorbell connected to 2.4ghz try to connect chime to tries to connect to an arlo network that i dont have password for that i didnt create. says unable to join arlo_1933
try resetting device and also take pic on another phone or ipad so can blow image up and move closer and farther away from QR code
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
