  • 11 Replies
  • 2100 Views
Amr1043404
I recently bought a house without a chime box therefor I don’t have the power kit installed. I did put in a new transformer and I am able to get power to the doorbell. However once I get to the QR code it never picks up the doorbell. I double checked to make sure I am on the 2.4 ghz frequency. Is there a way to reset it? Am I doing something incorrectly? Any suggestions is appreciated, I’m out of my return window so I am hoping to figure it out.
11 REPLIES 11
Does it chime?
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
Amr1043404
@stephen there’s no chime box so it does not
You are misunderstanding.
When you onboard to home wifi (as opposed to the base), you show the video doorbell a QR code generated in the app.
The video doorbell itself will chime when it successfully reads that QR code.  Are you hearing that?
Amr1043404
No, only thing I hear is a “click” on the doorbell when I hold the QR code up to it..
ShayneS
Are you still experiencing this issue?
Amr1043404
Yeah still doesn’t work
ShayneS
Have you tried performing a factory reset? I have provided the article here: How do I reset my Arlo Essential Video Doorbell?
Amr1043404
Yes it just flashes white but it has been flashing white for weeks now
ShayneS
Have you tried all the onboarding steps here? Flashing white. The doorbell was pressed and is discovering a WiFi network, SmartHub, or bases station. If your doorbell fails to discover a WiFi network My Arlo Essential Video Doorbell wasn't found during setup; what do I do?
Amr1043404
The camera was stuck in discovery mode. None of the trouble shooting steps worked. I finally just went to the breaker and shut down the power to the doorbell. Once that happened I was able to set it up without any issues.
ShayneS
Thanks for the update
  • 11 Replies
  • 2101 Views
