Arlo wired doorbell help with installation
I recently bought a house without a chime box therefor I don’t have the power kit installed. I did put in a new transformer and I am able to get power to the doorbell. However once I get to the QR code it never picks up the doorbell. I double checked to make sure I am on the 2.4 ghz frequency. Is there a way to reset it? Am I doing something incorrectly? Any suggestions is appreciated, I’m out of my return window so I am hoping to figure it out.
Does it chime?
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
@Amr1043404 wrote:
@stephen there’s no chime box so it does not
You are misunderstanding.
When you onboard to home wifi (as opposed to the base), you show the video doorbell a QR code generated in the app.
The video doorbell itself will chime when it successfully reads that QR code. Are you hearing that?
Are you still experiencing this issue?
Have you tried performing a factory reset? I have provided the article here: How do I reset my Arlo Essential Video Doorbell?
Have you tried all the onboarding steps here? Flashing white. The doorbell was pressed and is discovering a WiFi network, SmartHub, or bases station. If your doorbell fails to discover a WiFi network My Arlo Essential Video Doorbell wasn't found during setup; what do I do?
Thanks for the update
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
