Power went out - doorbell won’t work
  • 8 Replies
  • 6134 Views
TrantP13
I have a wired Arlo video doorbell on my front door. Last week the power went out and the app said my doorbell went offline. I tried everything - seeing if it would turn on, resetting it, and unwiring it/setting it up all over again. It won’t turn on and I never get a light to show up. Anything I can do here? Any ideas on what might be going on?
TrantP13
Finally managed to get it figured out after working with customer support. I turned off the circuit breaker that powers my doorbell for 20 seconds, flipped it back on and then it turned on! I had to do a factory reset on the back of my doorbell to get it connected to my app/hub again but hopefully that’s helpful for you.
8 REPLIES 8
There is a small internal battery that might need to recharge.  So you could wait a little while, and then try again.
TrantP13
I appreciate the response. It has now been connected to the electricity for a full week after the power outage and still no lights. I’d guess it wouldn’t need more time than that to recharge?
No, it shouldn't.
Have you checked the circuit breaker that feeds the transformer?
billn86
Were you able to power it up?  I have the same problem albeit from a different reason.  I did a software update and now the camera/doorbell is dead.  I have pressed the reset button numerous times and still can't get any lights.  Any suggestions would be appreciated.
TrantP13
I have not been unfortunately. I’ve let it recharge for a few days, tried resetting it multiple times, and even went back through the whole set up process again. I can’t seem to turn it on, I’m afraid it’s dead but hoping there’s an easier solution than finding a different doorbell to replace it.
TrantP13
Yes, I had to switch off the breaker to go back, unwire the doorbell, and set it back up. Testing my old doorbell and it seems to be working fine. Is there a way I can test the Arlo doorbell after detaching to see if it’s dead or not?
rondunn333
same issue power went out and now doorbell is dead no matter what I do. It has power to unit
TrantP13
  • 8 Replies
  • 6135 Views
