  • 7 Replies
  • 1736 Views
siorghlass
I've been having trouble getting my doorbell to connect to WiFi. It recognizes the QR code. I've turned off my router's 5Ghz band. I've set my phone so it won't switch networks. The doorbell blinks white for about 15 seconds then flashes amber and stops altogether. Any ideas?
7 REPLIES 7
Try the reset procedure outlined in the FAQ in the support area here. Hold the little button for >10 seconds until it ring flashes and try again.
siorghlass
Swap at the store or use the Contact SUpport link at the bottom here.
siorghlass,
Be sure you're entering the SSID and password exactly (case sensitive).
Damot
The other issue done the update of the app (Android) a couple of days ago the the option for adding a wire free video doorbell is not available on the app. Only the wired option is available.
Damot,
You may need to uninstall and reinstall the app if you're not seeing an option to onboard the wire-free doorbell.
Thanks - that fixed it here.
  • 7 Replies
  • 1737 Views
