However I thought I’d take the battery out and get it up to 100%, but an hour later and the led is still solid red.
Seems like the battery itself is not recognising when it’s charged. Or maybe is refusing to get to 100%.
I’m using an official Arlo cable (not sure if it’s the one that came with the doorbell or not, they all look the same)
Anyone seen this?
Just to update, the doorbell did finally charge. It took longer than expected.
However, not all usb cables seem to allow the doorbell to show it's actual charge status (hence why I was not seeing higher % after charging for hours). I ended up using the charger that came with my Pro 2 camera.
The doorbell batteries take ~6 hours to charge since they're a much higher capacity than those use in the cameras.
