How do I disable motion detection on the wireless doorbell? Can only find how to limit the sensitivity but not how to completely turn it off? I live in an apartment building and don't want to get notifications every time someone passes our door.
I haven't seen such a feature in the settings, but you can switch the mode into disabled.
Then, I still don't know if the motion detector is disabled, or if it is enabled, but no logic is triggered when a motion is detected ... (which will not save your battery !)
Thanks for the tip!
That could be a solution. Some more customization from Arlo would've been appreciated though.
Happy Easter!
/T
