Hi. I have a AVD2001Aer1.2 and iPhone 12 and I cant get the 2-way audio to work. I can hear the visitor in the iPhone but audio from iPhone to the doorbell does not work. iOS is 15.1.1 and the app ver is 3.5.10(2888).
What can be wrong?
What can be wrong?
Hi. After sw upgrade in the app to 3.5.12 the 2-way audio works fine.
Lasse_shall,
If you attach headphones, are you able to hear audio?
If you test using a different device, do you experience the same behavior?
Hi. I have tried on IPhone 12 and 11, same result. I tried on iPhone 12 with jabra wire free headphones, same result. I will charge my old Samsung tonight and test again.
Hi. I have now tested with a old Samsung and then 2-way sound worked. Do anyone know how to solve this problem? I have iOS 15.1.1 on the iPhone 12.
