Will the pro 3 charger work to charge the ultra camera .I know the wire is different
The pro 3 charger is identical to the ultra (and the cable is also identical). Also, both cameras use the same battery.
7 REPLIES 7
I made a mistake what I meant to say will the Pro 2 charger charge the ultra camera I know the wires different
I haven't tried charging an Ultra with the Pro2 charger. The Pro2 power output @ 5 volts is 1.8 amps - a bit less than the Ultra charger (which is 2 amps).
Thanks for the information
Pro 2 charger on the ultra camera seems to be working okay
it will work fine but only slightly slower charging.
Accessing Local Storage
