When was the last update? Also do you get notifications of updates or it does it update automatically? Was there any major changes?
New firmware for the SmartHub released last night addressing issues some users were experiencing after the previous firmware release. For more information on this firmware, take a look here: Arlo SmartHub VMB5000 - 1.12.3.2_134_185068d - 19th August 2019
Thank you,
camera or base firmware....
either way it should be an auto update
Release Details:
Arlo Base Station VMB5000-1.12.3.1_87_c950b94
Highlights:
- Battery Life Improvements
- Security Fixes
- Bug Fixes
Release Details:
Arlo Ultra VMC5040 - 1.070.41.1_80_9996bd9
Highlights
- Wi-Fi fixes
- Charging fixes
- Failed Stream fixes
- Other bug fixes
Still patiently waiting on an official firmware update to fix the problems with the previous updates.
Apparently Arlo sent out a Beta firmware update for select people to test out, that has so far looked promising. I would like to test myself but have no idea how to obtain the beta firmware.
Ultras were excellent before the update.
So hopefully the fix comes very soon.
Thank you,
It does appear that the new firmware has "fixed" the problem I was having with the cameras not recording or more pointedly saving video's but now it seems that things I had to do on the computer now have to be done on my phone, why does every fix break something else...
IMO firmware updates should be optional with notifications pushed that they're available, that way we can let some people apply them and report back if there are issues, I don't like being a beta tester with my security system.
Return them. I have regretted my purchase and wish I returned them while I still could. Now I need sell on offer up and go back to Nest Q
Did not fix the issues, I still cannot connect to one camera and get it to record and I have another I can connect to but it won't record.
I will totally buy one of your Ultra cameras. Just PM me and I’ll give you me email address!
Thanks!
@n1976jmk wrote:
Hi Notafan!
Thanks!
All or none.
notafanaorultra,
If you're still experiencing an issue after the firmware update, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Accessing Local Storage
