Has anyone else experienced this: my Arlo Ultra camera records video (14-120 secs) when audio noise is detected (under Library, thumbnails show Audio - and not Vehicle or Person) with the microphone turned off? How is that even possible?
Yes, you have to turn off the audio in the 'Rules' for the camera/s and not on the camera itself.
Do you have Audio on or off in your rules for the camera?
Had it 'ON" but the AUDIO DETECTION SENSITIVITY set to 2. Setting to 1 now to see what happens. I thought turning off audio under camera Settings would override?
As you found, settings in the camera settings aren't used for the rules. Editing your modes are the way to treat this properly.
Hey BTG - did you get this issue sorted, grateful to know how?? I've had the same problem for months. On windy days each of my 4 cameras batteries die in less than 24hrs -- incredibly frustrating -- have tried all sort of setting combos as well as complete reset. All malware is up to date. The system is terrible for the price.
Accessing Local Storage
