  • 14 Replies
  • 6947 Views
  • 2 Likes
  • 7 In Conversation
KGSRETIRED
14 REPLIES 14
KGSRETIRED,
Can you provide more details about what you are experiencing?
Are you referring to the CVR timeline or a specific video clip from the library?
Do you see an error message that is preventing you from viewing?
KGSRETIRED
Cvr timeline, I drag back to the time I want and it doesn't start playing like it should. It just sits there.
Bluestreak20
Mine hasn't worked in a long time. I cancelled the service then decided to try again. It worked great for a few days. The last two weeks has been the same as what you've experienced. The recordings are there. Just unable to play in the iOS app. I can see them on the web interface. I've attached a screenshot of what the iOS app is doing.
A new version of the iOS mobile is now available: Arlo iOS App - 2.13 - 3rd March 2020
Do you experience the same behavior after downloading the latest version?
KGSRETIRED
Uninstalled and reinstalled app. Still says version 2.12
KGSRETIRED
Ok , have the updated app. Timeline seems to work only for the same day but it doesn't work if you go back.
KGSRETIRED
Timeline even when working for the same day doesn't show the color on the bar for when motion was detected. I thought there was at least 7 days storage on this cvr.
KGSRETIRED
I think you should not charge for cvr subscription until you can get it to work. Not very impressed.
El_Lobo_Malo
I can only view CVR live, if I drag to a previous time it skips right to live. I'm using a Samsung Note 10.
KGSRETIRED
Yeah I never could get a fix for this. No answers you just keep paying for a subscription that doesn't work!
Beckyd
I am trying to isolate security footage for the police. The timeline will not play. Tell me how I am meant to use this system AS a security system if accessing the timeline is impossible? This has been happening regularly. There seems to be issues accessing the cloud. This is at your end. The device is not faulty.
Why am I paying for this function if it does not work? Why am I trusting that this system will keep me safe when it does not work?
Beckyd,
If you're still experiencing this issue with the latest version of the Arlo Mobile app installed, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
MelissaJane
The playback continuously won't play.  It shows a recording but you can't get it to play. it just shows like it is loading but never does.  It doesn't matter if I use Chrome, Explorer, or and Android app.
michaelkenward
Sensei Sensei
Sensei
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
Just another user
  • 14 Replies
  • 6948 Views
  • 2 Likes
  • 7 In Conversation
