TP link mesh connection
  • 4 Replies
  • 6141 Views
MrsG83
Hi, I am looking to get the Arlo ultra with 2 cameras plus a doorbell. I use a TP link mesh system as the WiFi is terrible. The TP link does have ethernet ports on all its nodes, would I be able to plug the Arlo base unit into a node instead of the router (which is in modem mode). The distance from my router to the cameral will be quite big but I do have a mesh node that is quite close. Thanks
n1976jmk
Virtuoso
Virtuoso
No because the Arlo Ultra cameras use the Smart Hubs WiFi only. Not any of the home WiFi.
n1976jmk
Virtuoso
Virtuoso
Hi mrsg83, you can plug your Smart Hub into one of the TP link's.  I do the same but with a Netgear Nighthawk model.
MrsG83
Thankyou, do you find it effects WiFi speed from the node?
n1976jmk
Virtuoso
Virtuoso
MrsG83
Lovely, thankyou for your help.
  • 4 Replies
  • 6142 Views
