Timeline won't play
KGSRETIRED,
Can you provide more details about what you are experiencing?
Are you referring to the CVR timeline or a specific video clip from the library?
Do you see an error message that is preventing you from viewing?
A new version of the iOS mobile is now available: Arlo iOS App - 2.13 - 3rd March 2020
Do you experience the same behavior after downloading the latest version?
I am trying to isolate security footage for the police. The timeline will not play. Tell me how I am meant to use this system AS a security system if accessing the timeline is impossible? This has been happening regularly. There seems to be issues accessing the cloud. This is at your end. The device is not faulty.
Why am I paying for this function if it does not work? Why am I trusting that this system will keep me safe when it does not work?
Beckyd,
If you're still experiencing this issue with the latest version of the Arlo Mobile app installed, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
The playback continuously won't play. It shows a recording but you can't get it to play. it just shows like it is loading but never does. It doesn't matter if I use Chrome, Explorer, or and Android app.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
Just another user
Accessing Local Storage
