This issue should now be resolved on the latest Arlo Android app version, which is version 2.19. You can read more about it here: Arlo Android App - 2.19 - 14th August 2020
If you're still experiencing this issue, please let us know.
Hi HazzMatt,
Thanks for raising this up. I was also able to replicate this issue and reported this to the development team for them to further investigate. When we hear any new information/update, we'll let the community know.
I noticed the exact same problem on my iPhone, as well as playing clips on the Arlo website on my laptop (MacOS). This is a deal breaker for me and my brand new Arlo Pro 3's. Absolutely critical to be able to zoom in on a static frame to get a positive ID on a person. Very likely to return if not fixed within the week.
JessicaP, can you please tell me if the Arlo Ultra has the same problem with playback. I most likely will have to return my Arlo Pro 3's, but the Ultra might work for my needs if playback for that camera allows for zooming on static frames.
Our team was able to identify this issue and is working on a fix. We'll provide an update when this fix is rolled out for this issue. We appreciate everyone's patience about this.
Thanks for the prompt reply JessicaP. Any idea on how long it might take for the fix? Not to be pushy, but I have a narrow window for return at BestBuy (15days) and I still need to test the efficacy of the zoom capabilities, even after the fix.
I'm presently on hold with Arlo support (it's been about an hour) trying to determine if the Arlo Ultra has the same problem. Any chance you can answer that question, and/or put me in touch with a tech support person? Is the playback platform for the Ultra the same as the Pro 3's, aside from the obvious difference in resolution.
This is affecting for other Arlo cameras as well on the Arlo app on Android. We haven't heard from the development team of when this fix will be coming but it should be coming soon. We'll be sure to provide any updates when we hear any new information.
What are the prospects for resolution of the problem with iOS and/or desktop use?
This issue should also be fixed on the latest Arlo iOS app version, which is also version 2.19. You can read more about it here: Arlo iOS App - 2.19- 17th August 2020
For the web client on your computer, the development team is still looking into this. Follow this thread to keep an eye on the web client: Unable to zoom when paused on web (via PC)
						Accessing Local Storage1
						Arlo Mobile App282
						Arlo Pro 31
						Arlo Smart180
						Arlo Ultra9
						Before You Buy434
						Features290
						Fehlerbehebung1
						Firmware Release Notes39
						Installation300
						Online and Mobile Apps113
						Service and Storage110
						Smart Subscription3
						Troubleshooting1,827
