  • 1242 Views
LandJS
Mentor
Mentor
Out of ten recordings this evening 8 were 0 secs long and 1 was 1 sec long.  Can't somebody at Arlo fix this issue.
This can be caused by signal strength/quality - anything that causes an issue with the connection between the camera and hub.  I'd start with rebooting the hub and reinserting the camera battery. You can also swap cameras around to see if it's the camera or location.
LandJS
Mentor
Mentor
signal was full on all, hub was rebooted twice yesterday and it affected 4 cameras so I doubt swapping them will help.  Even removed and re added 2 of them to try to stop it which is a pain now if you have more than 5 cameras because then you have to go through the inactive need a subscription crap until you can get them back to the active list.
LandJS
Mentor
Mentor
No Arlo I did not get an answer or solution
  • 1243 Views
