Ultra Charging issues
  • 4 Replies
  • 8035 Views
  • 5 In Conversation
Cmurphy512
I recently purchased (3) Ultra bundle have nothing but issues charging these. I just had to go out buy another “outdoor” charger and after 2 weeks this is not working either. Are these unable to charge when it gets cold out?
michaelkenward
Sensei Sensei
Sensei
A couple of related discussions at different extremes:
"your camera needs to warm up before you use it" i... - Arlo Communities
Read article about Arlo Pro not affected by heat. ... - Arlo Communities
Just another user
Cmurphy512,
Low temperatures can prevent your cameras from charging. For more information on this, take a look here: How do I keep my Arlo batteries charged in cold weather?
JesperDV
I have the exact same issue with my cameras, none are charging. Then unplugging and plugging the battery sometimes helps, but I have to do a lot of times... a lot like 20-30 times and then just maybe. Lately however this does not help. I have tried charging different cameras, switching hubs and batteries nothing works. I have tried using an Apple iPad charger instead, but nothing works... this camera really has severe issues with charging.
I've had a couple of occasions where I cleaned the contacts on both the camera and charger connector to reliably make it work.  Otherwise, use the Contact Support link at the bottom here for a possible hardware issue.
  • 4 Replies
  • 8035 Views
  • 5 In Conversation
