Ultra Charging issues
A couple of related discussions at different extremes:
"your camera needs to warm up before you use it" i... - Arlo Communities
Read article about Arlo Pro not affected by heat. ... - Arlo Communities
Just another user
Cmurphy512,
Low temperatures can prevent your cameras from charging. For more information on this, take a look here: How do I keep my Arlo batteries charged in cold weather?
I have the exact same issue with my cameras, none are charging. Then unplugging and plugging the battery sometimes helps, but I have to do a lot of times... a lot like 20-30 times and then just maybe. Lately however this does not help. I have tried charging different cameras, switching hubs and batteries nothing works. I have tried using an Apple iPad charger instead, but nothing works... this camera really has severe issues with charging.
I've had a couple of occasions where I cleaned the contacts on both the camera and charger connector to reliably make it work. Otherwise, use the Contact Support link at the bottom here for a possible hardware issue.
Accessing Local Storage
