AbeG
I have a new Arlo Ultra (1st gen) and suddenly (has been fine up till today) I can NOT watch live through my iPhone app on WIFI but if I turn off WiFI cellular is fine however WiFI streams fine on my WIN 11 PC on the web.
Seems the APP on the iPhone is the issue but only using WIFI.
Steps I have taken:
Assigned static IP to base station (model 5000)
Rebooted base
Power recycled base
Removed and added back everything.
Signal says "strong" (base is less than 25 feet from cam)
When I click on the "PLAY" arrow while on WiFi it immediately returns to the play button but as soon as I turn off WiFI it's streams fine on cellular.
I am a pretty "technical" person so I believe I have tried everything.  Very weird that it only streams live in my house on Cellular but not wi-fi.  WiFI is about 700Mbps/30Mbps so thast isn't an issue.  I also have a different brand video doorbell and that streams live fine as well as everything else I have so connectivity isn't an issue as wi-fi is fine with everything else I have.
Running IOS 16 (and have been for 3 months without issue)
The latest firmware updates for base stations and SmartHubs included a fix that should resolve a majority of the issues with 2K/4K live streams. We are continuing to investigate some corner case scenarios that could result in 2K/4K live stream failure. If you're still experiencing this issue, please let us know.
Best answers
  • JamesC
    The development team was also able to reproduce this issue and is currently investigating the root cause. I will provide an update as soon as I have more information available to share.
108 REPLIES 108
CraigArlo
No live view happening this morning when I tap the play button. Anyone else?
Craig
Have you rebooted the phone and maybe reinstalled the app?
CraigArlo
I have, no luck.
Just tested here and all ok... in NY
but then again, it may depend on your location as there are different main servers/hub locations.
Have you checked for any outages?
https://downdetector.com/status/arlo/
https://statusgator.com/services/arlo
https://www.isitdownrightnow.com/arlo.com.html
Just tried one of my Pro 3s here with no problem. Maybe reboot the camera or even reinsert the battery to reset it as well as reboot your hub?
CraigArlo
Ok, just finished doing this to all 6 cameras. No luck. Play button touched to view live, "connecting clock" spins for a fraction of second, but does not connect. I have tapped play multiple times in a row for each camera, stil nothing. Cameras record when tripped as normal, no problem there.
Did you also restart the base?
CraigArlo
yes sir.
CraigArlo
If it matters, I run ios on apple, this morning was an update for ipad and iphone. ipad 15.7 and iphone 16.
AbeG
Just to add:  Same problem on my iPad Mini 6 and my wife's iPhone as well.  WiFI no live stream on app, cellular is fine.
Either it is an app issue or some new secret setting on my wifi network that I am not aware of.
Do you have 4K livestreaming enabled in the app?  If you do, perhaps try disabling it, and see if livestreaming works again.
Also, did you update to iOS 16 yesterday?  FWIW, livestreaming an Ultra works on my iPhone 12 mini - I haven't upgraded yet, and 4K livestreaming is disabled.
CraigArlo
ok, digging deeper, if I disable/toggle off "local 2k live streaming" in video settings, all cameras operate normally. However, this makes 2k viewing feature useless. Perhaps Arlo can investigate further?
AbeG
Well I'll be darned ..... turning off 4K worked but 4K has been working for a week since I got this without issue.  NO, I didn't update yesterday because I have been running IOS 16 for months and have had the release version for about a week.  Nothing changed on this end from last night to this morning except that it's a new day.  🙂  Guess it's the same issue with my iPad Mini 6.
In any case, thanks for the temporary fix.  I should have my 14 Friday and hopefully won't have to disable 4K.
shatzini
Good afternoon all.
My Arlo 4 Pro camera, registered to a Base Station, is able to successfully detect and record motion.  Even notification works.
However,  when I click on the camera itself (from the app) to view live video, nothing happens.  I’ve tried on both iphone and ipad.  Lastest version/firmware on everything.  It’s worked in the past….
Looking for suggestions.
Some users who upgraded recently to iOS 16 have reported this.
If you have 2K livestreaming enabled in the app, then disable it for now.  That seems to work around the problem.
shatzini
That did it.  Much thanks StephenB !!
AbeG
Lol, 2+ hours of troubleshooting and hair pulling and, as I originally guessed, the issue is on your end.  🤪
Thanks though for the confirmation.
Davatx
Hey, mine are doing the same thing.
I’ve gone through all of the suggested steps and still no streaming. I’m also on iOS. Powered on and off my device and still no joy.
Let me know if you figure it out.
Including disabling 2K (or 4K) live streaming in the app?
yo123
Same here. It was fine yesterday(Sep.12)  "after" ios16 update, still fine. Most likely related to today's firmware update of VMB5000 - 1.20.0.3_1322_a114662
I had to turn off local 4k live streaming, and watch no-4k live.
kng112
Hi. All my ultra 2 cameras can’t see live streaming on the app, only works on my desktop and my sister phone. I also use my account to login into my sister phone still can’t view live streaming. I’ve try everything, plug/unplug, take the battery out, reset the base station, even tho I’ve uninstall the app and reinstall back still doesn’t works. Already contacted support, he can’t fix it also. This is my 2nd time of having issue with different problems that I’m having within 3 months, so disappointed.
Nanookie
I just submitted a ticket recently regarding a firmware issue on my vmb5000r4. One of my 3 smart hubs wasn’t updating to 1.19xxx and the live stream wasn’t working. Got this resolved finally, this weekend, and all my bases were on 1.19xxx and all my cams were properly live streaming in 2K or 4K. Just today, 3 days after everything was resolved, live stream wasn’t functioning again, and low and behold, another firmware update was released. I know my system pretty well, the new update obviously the issue.
Come on, Arlo. I’m reading patch notes that indicate bug fixes—well, you got more bugs.
If 4K livestreaming is enabled in your app, try disabling it (for now).
