I had a similar problem recently with three of my 6 Ultras after a firmware release.. The motion detection icon on the devices page would turn amber, but I was not getting any recordings or notifications. I don't know if this will help you or not but how I solved the problem is as follows:
For each camera that was affected I
1) removed the camera from my account.
2) power cycled the hub
3) added the camera back to my account.
Been 3 weeks or so and the problem has not returned.
Brian
Sounds similar to the issue that I and lots of others appear to be having - more in other threads, but if it's the same problem then the bottom line is that there isn't a fix yet. Suggest you call Arlo and log the problem.
Brian
Cheers.
AVM4000C-100NAS Arlo pro 3 Camera Kit
You have a question? Does it have anything to do with the original post?
Just another user
This problem is far from being resolved. It's October 15 and I have alerts but nothing in the library since 2:15 am. These cameras are beyond useless and a total waste of money.
Can't wait for my Ring Camera's to arrive so I can dump these worthless Arlo cameras
same on two different house two different base stations, not recording to cloud!
Many have the same problem. Talked to support but no fix. I solved it when I removed all my cameras from the Smart Plan. After 10 min my smart notifications was gone and only dummies like sound or motion was received but then my recordings start to work again. When swift back to smart plan the recordings stopped working. So Arlo have a big problem with smart plan.
If they are having a huge issue with the Smart Plan, then they need to refund all uses that have it.
I'm completely done with this company and the constant issues with their cameras. My new cameras can't get here fast enough
Can I add the cameras back to my account without taking them down?
2-3 days is BS. They need to refund us for the premier plans that we are paying for.
Today the base station is offline and can't be turned back on unless you are there with it. What good are these cameras if they only work sometime. I feel my home is more unsecure now more than ever
Again, can't wait for my new Ring cameras.
This morning about 6:30am, my neighbor's car was stolen out of her driveway. My Arlo camera focused on my driveway has a perfect view of the neighbor's. She asked me for the camera video for the police to use. I went to my recordings and, surprise, that camera hadn't recorded anything for the past 5 days. The camera was charged, worked in live mode, and registered movement, but never recorded. It missed a crystal clear shot of the thief breaking into her car. Thanks Arlo!
My neighbor is buying herself a new security system. She is staying far away from Arlo thanks to this experience.
